Timing chain question - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 02-02-2008, 08:12 AM Thread Starter
Date registered: Feb 2008
Hello all, I am new here, and currently looking at buying a 1979 450 SEL. The car has 80,000 miles on it, so everything is pretty tight except the seller said that the timing chain broke. He also said that the dealer told him that the engine (4.5L) is not an interference type. From reading some of the threads here, it sounds like he's feeding me a line! Can someone please tell me the truth?
Hoolio is offline
post #2 of 3 (permalink) Old 02-02-2008, 10:49 AM
I've been there, same motor, same thing.
It does interfere, bent valves,
can you do the fix yourself? (if not plan on $2,500 for job)
The good part.......
This motor had 215,000miles on it and after valve job smogged better than new.
the piston tops had a very light soft crust, still had hone marks in bores.
don't pay more than $1k for it. maybe more if the body is perfect
Brian O
bostosh is offline
post #3 of 3 (permalink) Old 02-05-2008, 08:26 PM
Date registered: Apr 2007
Vehicle: 1999 E320, 1975 450SEL, 1979 280SE
Quoted: 8 Post(s)
Hi and welcome! Where are you located?
Peter
rabbit188 is offline
    Another Timing Chain Question matts R/C107 SL/SLC Class 3 04-26-2007 05:03 PM
    Timing chain question MB190E2.6 W201 190-Class 11 03-09-2006 04:01 PM
    Timing chain question Michael Pillay W126 S,SE,SEC,SEL,SD,SDL Class 2 02-06-2006 06:06 AM
    timing chain question DpnzonDaBnz W126 S,SE,SEC,SEL,SD,SDL Class 3 01-01-2006 11:53 AM
    Timing chain question zSeXc1 W201 190-Class 4 08-11-2004 02:12 PM
