Go Back   Benzworld.org - Mercedes Benz Discussion Forum > General Mercedes-Benz Forums > Vintage Mercedes-Benz
Old 01-20-2008, 06:24 PM   #1 (permalink)
Date registered: Jul 2007
MFI questions for 300SE
I got my car running again this weekend. Plugs were wet. I verified spark from the coil, spark from each plug wire, removed cold start valve cleaned and reinstalled, checked the solinoid for CSV got engine started but it is not running on all six.
Can I remove the injectors and clean? Pump was replaced with a running pump, but I am not sure it is even the right pump.
Thanks for all your responses.
Jim
1965 300SE needs everything.
jim dorociak is offline   Reply With Quote
Old 01-20-2008, 09:25 PM   #2 (permalink)
Date registered: Dec 2003
Vehicle: 1989 300SE, 1989 420SEL, 1965 220S, 2002 Ford Crown Vic Police Interceptor
The 300SE, what year and model, W112 or W111 CP/CV, must use the correct pump. If the engine is the M189, 3.0 all Al six, get the pump type and post it. Check 300SE_Main_Page_1 as well, click on production changes, engine then fuel injection pump, for a list of injection pumps. The early ones used a 2 plunger pump, the later ones a 6 plunger pump.
More INFO and some pics please.
Near Manassas Va. '89 300SE, 2002 Ford Crown Victoria Police Interceptor, 89 420SEL
Had '65 220SE, 67 230S, 72 280SE 4.5 Dad had '65 300SE LWB, '65 220SE
"Of all tyrannies, a tyranny sincerely exercised for the good of its victims may be the most oppressive." C.S. Lewis
wbain is offline   Reply With Quote
My first 300SE - some thoughts and questions philthompson W126 S,SE,SEC,SEL,SD,SDL Class 4 01-16-2007 10:20 AM
Questions from a 300SE Newbie Ted_J W126 S,SE,SEC,SEL,SD,SDL Class 3 09-01-2006 03:44 PM
Newbie, transmission questions on my 86 300SE Carolina28 W126 S,SE,SEC,SEL,SD,SDL Class 2 03-02-2006 08:02 AM
Specification MFI sensor and relays W111 1963 220SE MercedesOtto Vintage Mercedes-Benz 0 01-17-2006 11:07 AM
Bosch MFI pump....what is it worth? fokoracer Vintage Mercedes-Benz 1 12-25-2005 06:24 PM
