Go Back   Benzworld.org - Mercedes Benz Discussion Forum > General Mercedes-Benz Forums > Vintage Mercedes-Benz
Old 12-23-2007, 01:40 PM   #1 (permalink)
Date registered: Nov 2003
Tires for vintage MB's ~ 1973 280SEL 4.5 ~ 185/70/14
I just bought a 1973 280SEL 4.5 with 111K documented original miles. The car has black wall Michelin 185/14 XZX's which need to be replaced due to age. I contacted the Classic Center and they are suggesting Michelin Harmony tires in 205/70 black wall.
What do you think about the increased tire size and lack of whitewalls as the car came with whitewalls new? Are there any other brands I should consider? The 4.5 will be used at a second home and probably driven in good weather only, under 1000 miles/year.
E430_4Matic is offline   Reply With Quote
Old 12-23-2007, 05:48 PM   #2 (permalink)
E=MBČ
GermanStar's Avatar
Vehicle: GermanStar.net
I concur wholeheartedly with the recommendation of the Classic Center.
German Star
GermanStar is offline   Reply With Quote
Old 12-29-2007, 10:30 AM   #3 (permalink)
Date registered: Aug 2006
The original tire was probably 185/82-14. No such tires are now available. If you want to keep the same diameter and thus accurate gearing for the transmission and speedo, the nearest equivalent is 195/75-14. 70 series is wrong! There are several good choices from Kumho, Dunlop, Goodyear, Michelin etc.. Go to Tires-easy.com or tirerack.com
Gazolba is offline   Reply With Quote
Old 12-30-2007, 04:55 PM   #4 (permalink)
roncor's Avatar
Date registered: Jan 2005
Vehicle: '87 560SL '93 190E 2.6 Sportline '80 240D
Check out this tire sizing chart, it might help.
Tire Size Helper
roncor is offline   Reply With Quote
Old 12-30-2007, 07:46 PM   #5 (permalink)
E=MBČ
GermanStar's Avatar
The original tires should have been 185/70-14,which are appropriate for a 6x14 rim. A lot of folks put 6.5x14 rims on their cars, which takes a 205/70-14. The 205s are noticeably wider and a better look.
Old 12-31-2007, 05:32 AM   #6 (permalink)
Will the 205/70-14's recommended by the Classic Center fit on my original stock 6x14 rims?
Old 12-31-2007, 05:49 AM   #7 (permalink)
Date registered: May 2005
Vehicle: '07 GL320CDI, '06 E320CDI
Get tires in CORRECT sizes here
Vredestein Classic Tires and Vintage Tires
Kent Christensen
Albuquerque
Old 12-31-2007, 07:07 AM   #8 (permalink)
E=MBČ
GermanStar's Avatar
They will, but it's not an ideal match. If you still have 6x14 rims, 185/70-14 would be a better match. OTOH, you might be able to find some used 6.5x14 rims for a song and a dance.
Old 01-02-2008, 11:28 AM   #9 (permalink)
roncor's Avatar
Coker Tires has your size: 185/14 here:
Coker Tire Company :: Search results
...And their recommendation for your car here - including White Walls:Coker Tire Company :: Search results
1973 280SEL 4.5: Your opinion, please! 550maranello Vintage Mercedes-Benz 7 03-07-2008 05:42 PM
1973 280SEL 4.5 MBZ300CD Vintage Mercedes-Benz 13 09-03-2006 01:18 PM
plugs and wires 280sel 4.5 1973 ldshull Vintage Mercedes-Benz 7 06-14-2006 03:57 PM
Is this 280sel a 1972 or 1973? ldshull Vintage Mercedes-Benz 8 01-29-2006 07:18 PM
Buying 1973 280SEL 4.5 -Anything to watch for? ldshull W116 S, SE, SEL, SD Class 6 01-13-2006 11:20 AM
