Suispected Water Pump Failure - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 12-18-2007, 08:35 AM Thread Starter
Date registered: Dec 2007
Vehicle: 1972 280SE, 2003 Nissan 350Z
Hi Guys,
I am new to this forum, and firstly wanted to introduce myself. I look forward to talking to you all in the future here on this site, and maybe learning a little bit about my benz.
I have a 1972 280SE with approximately 52,000 original miles on it. Last week the fan belt split apart, and that was replaced with a new one. The week before, I had an issue with the car getting hotter than normal, and found this to be low coolant in the radiator. Upon inspection, I did not notice any leaks. I suspect that the coolant is leaking out the top valve near the radiator cap, when I think there should be a resevoir. I suspect since the cap isn't creating a good seal, there isn't enough pressure keeping the coolant in, and its leaking out of that valve. Does anyone have any experience with this type of issue. I have added fluid, and it doesn't appear to be leaking, and the fluid is almost exactly where it was when I filled it up.
Now, after the fan belt has been replaced, I finally got the chance to drive it again. Now it is making a chirping noise. It only starts usually when I give it gas, and goes away quickly. I have also noticed it to occur when slowing down. It doesn't always fit the same pattern however. I suspect a failing water pump. Do you all think that could be the case, or could it be something else?
Thanks, Jeff
FSTRNHM is offline
post #2 of 3 (permalink) Old 12-18-2007, 10:49 AM
Date registered: Sep 2003
Vehicle: 111.010
Remove the belt and spin the water pump by hand - if it isn't smooth/easy the pump is failing. Your pump may have weep holes that indicate the pump is failing also.
Search first, ask second!
mb230s is offline
post #3 of 3 (permalink) Old 12-18-2007, 04:23 PM Thread Starter
Does anyone have a partial or complete service manual for a 1972 280SE 6-cylinder with A/T tranny? I was hoping I could get a copy of someones manual so I know what to look for.
Thanks, Jeffrey.
FSTRNHM is offline
    92 400E Power steering pump and water pump, need advice kanio W124 E,CE,D,TD Class 5 03-19-2007 05:58 PM
    Name that sound: water pump, P/S pump, tensioner? jamesvyu W163 M-Class 9 01-05-2007 07:15 AM
    Vacuum Pump Failure AMSOIL300CDT W123 E,CE,D,CD,TD,TE Class 7 12-11-2005 11:35 PM
    Water pump leaking steering pump loud abentley79 W124 E,CE,D,TD Class 3 08-31-2005 04:50 AM
    Lock Pump Failure MadMaxBronze R170 SLK-Class 4 11-10-2004 06:14 PM
