1982 300D Vacuum Help - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 12-09-2007, 01:34 PM Thread Starter
Date registered: Dec 2007
Post 1982 300D Vacuum Help
I need a vacuum diagram for this car. A rodent made a meal of the rubber lines and most of the t's. Pictures would also help if possible.
malibuz16 is offline
post #2 of 6 (permalink) Old 12-09-2007, 02:08 PM
Rmac58's Avatar
Date registered: Nov 2007
Vehicle: 2013 MINI Copper S Clubman, '84 300CD-weekend car
Quoted: 139 Post(s)
Try using the search button above. Under hood? Which lines? From pump?
'13 MINI Cooper Clubman S-daily driver
'84 CD-weekender!
Rmac58 is offline
post #3 of 6 (permalink) Old 12-09-2007, 03:01 PM Thread Starter
Lets see...from the check valve next to the booster, from the lines into the cabin for the central locking system, transmission, and the IP shut off. I have tried to search...but most of the diagrams are too fuzzy or colors dont match.
post #4 of 6 (permalink) Old 12-09-2007, 03:13 PM
Rmac58's Avatar
Quoted: 139 Post(s)
Is your big main line OK?
Pics may, or may not help. This is my CD currently, the EGR vac system is out of the loop, so it's not a stock set up, as is the vac line, sorta, for the turbo switchover valve.
Name:	next to smallest file 004.jpg
ID:	153033   Click image for larger version
Name:	next to smallest file 005.jpg
ID:	153034   Click image for larger version
Name:	next to smallest file 008.jpg
'84 CD-weekender!
Rmac58 is offline
post #5 of 6 (permalink) Old 12-09-2007, 04:44 PM
MBeige's Avatar
Date registered: Jan 2004
Vehicle: W-1-2-3 Go!
Quoted: 204 Post(s)
Under my username, search for "vacuum diagram"
You'll need 3 of the 3 way fittings and 1 of the 4 way fittings
Get at least 3 meters of the regular vacuum line and just cut to fit
I hop that rodent did not eat away at the fuel lines too! Double check for fuel leaks.
Enjoy working on it also this should be moved to the w123 section, that's where you'll get a good vacuum diagram under my name
MBeige is offline
post #6 of 6 (permalink) Old 01-30-2013, 02:30 PM
Date registered: Jan 2013
DOH!
You are a life saver. Thanks for the pics. I put together a bunch of posts and parts of my manual. You made it all come together enough in one place that I figured out my problem.
Jim Cooper is offline
    Do It Yourself (DIY) repair thread and wheel and tyre thread Dr.Grillz W126 S,SE,SEC,SEL,SD,SDL Class 228 03-08-2017 09:44 AM
    transmission vacuum questions: 1982 300TDT whyameye W123 E,CE,D,CD,TD,TE Class 6 07-06-2006 06:04 PM
    1982 300d ilikemercedes W123 E,CE,D,CD,TD,TE Class 0 10-18-2004 11:05 PM
    1982 300D A/C question H-TownBenzoboy W123 E,CE,D,CD,TD,TE Class 0 10-10-2004 07:58 PM
    1982 300D cltaylor38 W123 E,CE,D,CD,TD,TE Class 4 03-02-2004 06:30 PM
