W112 300SE Long Wheel Base - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 11-29-2007, 02:23 PM Thread Starter
Date registered: Feb 2007
Vehicle: 1994 S500,1995 S320,1998 S500,2000 Lexus RX300,2001 E430 4Matic,2003 S600 Sport,2003 ML500
I am looking at purchasing a 1965 300SE LWB.It has been in dry-storage since 1971.The body is solid,just dusty.Interior is in tact,keys,manuals everything.Wood is still very nice.The car does not start and car is sitting very low.I do not know if the air-suspension is good or not.How easy is it changing the suspension from air to coil spring?Should I fix the suspension or change it?
npatel219 is offline
post #2 of 5 (permalink) Old 11-29-2007, 03:17 PM
Magnetoz's Avatar
Date registered: Aug 2007
Vehicle: 1973 280SE 4.5L, 1974 240D, 1984 300D Turbo
Repair of the air suspension is very costly. If you want to restore to show condition you better fix it. If you just wan the car for fun to tool around in you could probably swap coil suspension from a w111.
Magnetoz is offline
post #3 of 5 (permalink) Old 11-30-2007, 01:09 PM
drew56cus's Avatar
Date registered: Oct 2006
Vehicle: 1965 220SE sedan (finnie) with 450SE conversion, 1964 220SE coupe project, 1966 300SE coupe
Quoted: 32 Post(s)
If what you say about the car is correct, you have found a desirable and original car. I have read a bit about these cars on 300SE_Main_Page_1. Chris has put together a great deal of info about them. From what I have read, if the cost and idea of fixing the air suspension daunts you, then these cars are probably not for you. Distributor caps cost hundreds of dollars for example. Buy a standard finnie to get your kicks, and leave the 300SEL to be restored to its former glory.
But looking at your list of cars, it would seem that you have enough resources to do the car right.
Now I am not an originality freak (putting a V8 in my finnie), but I believe that ditching the air suspension system is a backward step as it makes the car handle like a much more modern car than what it is.
Drew in Oz
drew56cus is offline
post #4 of 5 (permalink) Old 11-30-2007, 08:19 PM
Date registered: Jun 2006
Please leave the original air suspension. It may be costly to repair but it's what makes a 300 a 300. If you do not buy the car please let us know who to contact so one of us has a shot at getting it. Would love to see pics in the vintage gallery if you do make the purchase. Good luck!
klohle is offline
post #5 of 5 (permalink) Old 12-01-2007, 11:51 PM
ChopTop250SE's Avatar
Vehicle: 1967 250SE RHD, 1969 300SE L, 1989 560SEC with AMG upgrades, 1998 s600 coupe
Send a message via MSN to ChopTop250SE
I am all for tastefull custom work, improvisations etc. However, w112 300SE L is even more rare that a w109 300 SE L. That is a car that you leave alone, that is a car that should be restored not modified. The sad thing is, in that chassis only the 300 came in long version. So if someone wants that body on long, but does not want the troubles of the air ride, swapping is the way. OR, put a modern air suspension it will cost you less than half of what you will spend on restoring the original.
ChopTop250SE is offline
    95 W140 Long Wheel Base Shocks emayo00 W140 S-Class 12 08-12-2012 07:14 AM
    How do I tell if I have a Long or Short Wheel base? bdonkersgoed W140 S-Class 17 02-26-2011 04:45 PM
    Long and Short Wheel Base flair77 W168 A-Class 1 03-28-2007 12:42 PM
    LONG WHEEL BASE Stas W140 S-Class 13 10-20-2005 08:15 AM
    Long Wheel Base Interior Lock Boxes Jason Dickman (Europ G-Class 1 03-04-2002 09:32 AM
