Wheel interchangeability - Page 2 - Mercedes-Benz Forum
post #11 of 17 (permalink) Old 08-08-2008, 10:48 PM
wbain's Avatar
Date registered: Dec 2003
Quoted: 4 Post(s)
W126 S class wheels will fit.
wbain is offline
post #12 of 17 (permalink) Old 08-09-2008, 11:00 AM
Date registered: Jul 2004
Vehicle: 1971 280SE 3.5 Coupe
Quoted: 8 Post(s)
Here's a link I put on another post that might be useful:
15-17 Inch Wheels for Mercedes 108-109's
When I put different wheels on my 111 I had to use thin spacers to get just the right offset. I used high quality Hub-centric spacers and converted to studs instead of the bolts. Makes wheel installation much easier espesicially wide wheels.
3.5 Tony is offline
post #13 of 17 (permalink) Old 02-23-2011, 08:45 AM
CRJ9Driver's Avatar
Date registered: Nov 2009
Vehicle: 1956 Buick Century Coupe, 1937 Pontiac Business Coupe
Originally Posted by GermanStar View Post
Wish I had read this last week... You are right... the W201 ET49 will not fit my 63. I saw someone had them on, must have been different offset... They barely come flush with my studs.
CRJ9Driver is offline
post #14 of 17 (permalink) Old 02-24-2011, 05:56 PM
50$84sd's Avatar
Date registered: Oct 2009
Vehicle: 1965 220se w111 *******1984 300sd w126 *******1991 350sd w126
Had these same w201 et49 wheels on my w111 for years, no adapters or spacers just longer bolts and sledge to inner rear fenders. Later.
50$84sd is offline
post #15 of 17 (permalink) Old 02-24-2011, 07:13 PM
CRJ9Driver's Avatar
My hubs have studs... no bolts, so at this point there is not much I can do. I will take them tomorrow to a recycle yard see if they can take them as partial trade on something else with smaller offset. I don't feel like removing the pressed in studs... too much work.
post #16 of 17 (permalink) Old 02-24-2011, 09:31 PM
50$84sd's Avatar
Interesting, thought all w111 took bolts, hmmm. Later.
50$84sd is offline
post #17 of 17 (permalink) Old 03-05-2011, 06:23 PM
Gustav's Avatar
Date registered: Feb 2007
Vehicle: 1968 250SE
Modern 17" wheels on a W108
this is a '68 W108. The wheels are from a 2003 SL - 8.5*17 ET35. The fronts require a 15mm spacer to clear the shock absorbers and the rears needed a 10mm spacer to clear an internal body part (made from high strength steel). Studs have been installed on all four corners.
The tires are 235/45r17's. The inner fender edges did not require rolling at this time.
This combination fits perfectly. It is tight, but there nothing rubs anywhere and the tire/wheel combo extends out beautifully.
Gustav is offline
parts interchangeability? dugald R/C107 SL/SLC Class 1 05-15-2007 04:58 PM
rotor interchangeability andrew_falky W126 S,SE,SEC,SEL,SD,SDL Class 1 03-18-2007 06:54 PM
Newb Question about W202/W124 Wheel Interchangeability 94Wagenmeister W202 C-Class 1 11-29-2006 05:07 AM
1992 300e 4matic wheel interchangeability sach The Discount Tire Direct Tire, Wheel, Brake & Suspension 0 08-30-2005 05:09 PM
transmission interchangeability Guest (MBNZ) W123 E,CE,D,CD,TD,TE Class 1 04-10-2002 12:08 PM
