Go Back   Benzworld.org - Mercedes Benz Discussion Forum > General Mercedes-Benz Forums > Vintage Mercedes-Benz
Old 11-10-2007, 11:09 AM   #1 (permalink)
Date registered: Nov 2007
350SL with 450 motor from factory
I am acquiring a 1971 350SL that appears to have a factory 450 engine.
I have located the VIN on the door which is 107.04412-001061.
Can someone help with the meaning of the VIN numbers and if Mercedes ever put the 450 in the 350SL
Thanks
Tage is offline   Reply With Quote
Old 11-10-2007, 02:51 PM   #2 (permalink)
ChiefRider's Avatar
Vehicle: 1914 Ford 2006 Chrysler 300C 1988 560SL
The engine in every 350SL is a 450 V8. Go to the 107 section here and do search on vin numbers. There is a russian website that decaodes the vin. There is also a vintage MB center that can decose this for you. Search the 107 site- you'll vind lots of info on your car.
Chief
ChiefRider is online now   Reply With Quote
Old 05-31-2008, 06:55 AM   #3 (permalink)
Date registered: May 2008
Vehicle: 1971 Mercedes 350 SL 3.5L V-8
Chief,
You are incorrect. I have a '71 350 SL with all the ppwk and the engine is a 116-982 which is a high compression 3.5 liter V-8. Its marked on the block too. This car was not made for export to the USA but was exported in August of '71 to the USA, so there are a few of them out there. This was the standard european engine for the 350's.
Tage,
What I noticed was the vin# Now I thought 350SL's were 107.043.... 450SL is a 107.044... Does anyone know if Mercedes tagged the 350's with the 4.5 liter engine 107.044...??
red71-350 is offline   Reply With Quote
Old 05-31-2008, 09:15 AM   #4 (permalink)
E=MBČ
GermanStar's Avatar
Vehicle: GermanStar.net
Yeah, there are plenty of 350SL's with 116 engines in them....
German Star
GermanStar is offline   Reply With Quote
Old 06-01-2008, 08:52 PM   #5 (permalink)
Date registered: Dec 2003
Vehicle: 1989 300SE, 1989 420SEL, 1965 220S, 2002 Ford Crown Vic Police Interceptor
The early 350SL's that MB sent to the USA had the 4.5 engine instead of the 3.5. Later, the badging was changed to 450SL.
Near Manassas Va. '89 300SE, 2002 Ford Crown Victoria Police Interceptor, 89 420SEL
Had '65 220SE, 67 230S, 72 280SE 4.5 Dad had '65 300SE LWB, '65 220SE
"Of all tyrannies, a tyranny sincerely exercised for the good of its victims may be the most oppressive." C.S. Lewis
wbain is offline   Reply With Quote
Old 06-02-2008, 08:38 AM   #6 (permalink)
E-Class Owner's Avatar
Vehicle: 1997 Mercedes Benz E420
Correct...
IIRC, MBNA even offered to "re-badge" the early 350SLs to a 450SL free of charge. Most owners declined the offer, as the 350SL with its smaller, European style bumpers, etc., was a more visually appealing car than the '74 and up 450SLs, with their bulky Federally mandated "amusement park" bumpers, that followed.
JR
E-Class Owner is offline   Reply With Quote
Old 06-02-2008, 09:03 PM   #7 (permalink)
Thanks for that update.
350SL Should I get it ? bostosh R/C107 SL/SLC Class 17 06-14-2007 12:54 PM
350sl/450 Auto Gearbox Question 3 Speed? Peter Seow R/C107 SL/SLC Class 10 08-19-2006 10:45 PM
79 450 motor transplant to a 75 450SL ???? bc2885 R/C107 SL/SLC Class 4 06-21-2005 09:02 AM
1975 450 SL motor ahlj02 R/C107 SL/SLC Class 1 09-18-2004 09:30 AM
what motor oil did the factory use in the '99 SLK? Mike M R170 SLK Class 0 03-09-2002 10:40 PM
