W107 no heat...the more I look, the puzzler I gits...HELP!!!! - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 11-03-2007, 02:04 PM Thread Starter
Date registered: Jun 2007
With the glovebox out and flashlight in hand, I have a problem I cannot figure out. There's the flex tube which connects to the air sampler in the top center of the dash (I put a new piece of foam hose from Home Depot on it, GREAT fix!). The PROBLEM is that the other end of this flex hose is connected to NOTHING after it snakes around the wiring and ends up right near the accordion hose to the right fresh-air outlet. I KNOW that sampling hose has to go somewhere, considering George Murphy told me about an electro-mechanical switch in there somewhere that samples cabin air temperature and turns on the Aux Water Pump below 65 degrees F. For the life of me, I cannot find that blasted switch. I'll bet this end of the sampling hose goes to it.
This whole mystery is because my Aux Water Pump doesn't turn on, even though I've powered it with a separate 12V source and it sure goes like blazes then! There's no heat in DEF, either, so I suspect that the otherwise clean-looking OEM Servo is shot. Thank goodness I have one of George Murphy's rebuilds. He's checking it out for me right now, so my old Servo is still in there.
Can SOMEONE give me an idea where the other end of that snaky sampler hose I described, is supposed to connect to? And, what this device/switch is supposed to look like?
Thanks, gang!
Many Thanks and God Bless!!
Sandy Gerli
6205 Farrington Road, B4
Chapel Hill, NC 27517
(919) 489-9638
1979 450SL "Our Daisy" in Maple Yellow
1984 300DT "Kermit" in that nifty Petrol Green Metallic
1985 300SD "Sadie" in Pretty Black Pearl!
Sandy Gerli is offline
post #2 of 3 (permalink) Old 09-25-2012, 11:45 AM
Date registered: Jul 2012
Vehicle: 1967 250S, twin Weber carbs, automatic trans, power windows, A/C, R134a conversion
My guess is that the hose goes to the right-side vent. The vent typically would have a "Y" connection for the air-cond and the heater vent hoses leading to it
Kitaka is offline
post #3 of 3 (permalink) Old 09-25-2012, 11:33 PM
wbain's Avatar
Date registered: Dec 2003
I think you would be better off posting in the 107 forum.
R/C107 SL/SLC Class - Benzworld.org - Mercedes-Benz Discussion Forum
they would be the experts. Just trying to help.
wbain is offline
    1979 W107 450SL with no heat...questions... Sandy Gerli Vintage Mercedes-Benz 2 10-25-2007 06:04 AM
    Here's a real puzzler Digmenow R/C107 SL/SLC Class 6 09-03-2007 03:07 AM
    What's that noise? puzzler Dovebar W126 S,SE,SEC,SEL,SD,SDL Class 9 01-09-2007 02:21 PM
    Heat coming from steering coloumn... W107 tubbee R/C107 SL/SLC Class 5 06-25-2006 05:25 PM
    A little puzzler here. Darkmann W163 M-Class 7 09-17-2002 07:31 PM
