1979 W107 450SL with no heat...questions... - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 10-24-2007, 07:58 AM Thread Starter
Date registered: Jun 2007
Hi, fellas and gals: Daisy, our SL, has no heat. Everything else is fine - all A/C operations work correctly. The Aux Water Pump works (I powerred it up with a separate 12V source). SO....Either it might be the Climate Control Amp, ormaybe there's a little switch/solenoid in the chain that's open and not energizing? I also have one of George Murphy's great rebuilt Servos, but am keeping it in reserve as the original one doesn't leak and seems to be okay.
Can someone give me some hints on where to diagnose this further?
Better to e-mail be direct at ac1y@nc.rr.com
Sandy Gerli is offline
post #2 of 3 (permalink) Old 10-24-2007, 08:45 AM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 544 Post(s)
Welcome to BenzWorld Sandy! Check to see if you can get heat on your Defrost setting, If you do, that is a classic symptom of a failed ACC Amplifier. If you cannot get head on Defrost, you may be looking at a dreaded ACC Servo failure.
GeeS is offline
post #3 of 3 (permalink) Old 10-25-2007, 06:04 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 67 Post(s)
I agree with what Ron said. One quick check is to see if the coolant lines coming OUT of the heater core are hot.
flyboyike is offline
    Mb 280slc 1979 W107 agentk R/C107 SL/SLC Class 14 06-11-2007 05:44 AM
    1979 450sl Power Steering Questions houston14 R/C107 SL/SLC Class 1 02-03-2007 02:34 PM
    Heat coming from steering coloumn... W107 tubbee R/C107 SL/SLC Class 5 06-25-2006 05:25 PM
    Tires for 1979 450SL johnregnery R/C107 SL/SLC Class 5 12-06-2004 07:15 PM
    year 1979- W107- inline six how worth? burak sozer R/C107 SL/SLC Class 0 11-01-2002 07:06 AM
