dash board ? - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 10-10-2007, 07:08 AM Thread Starter
g.w.b's Avatar
Date registered: Dec 2006
Vehicle: 300D
Send a message via MSN to g.w.b Send a message via Yahoo to g.w.b
Question dash board ?
Have any one removed a w116 dash board I want to get a new one butte want to know ho hard it is to remove it can any one help me on it ?
ps : i did post this at 116
1991 160 monza (100 259 km)
1974 w116 300D (890 000 km)
S.A. ROCK
g.w.b is offline
post #2 of 5 (permalink) Old 10-12-2007, 12:10 AM
Date registered: Jun 2004
Quoted: 17 Post(s)
It's not hard but very time consuming.PLAN ON A FULL DAYS WORK.
start by removing the front seats.
the center console is next. be careful because the heater controls,shifter panel are all secured by hidden fastenings.
Remove the instrument cluster.
remove the glove box and it's lid.
remove the under dash panels on both sides.sometimes you need to take the kick panels out too,theres plastic trim in the way so be careful getting that off because it is all hard to find now.
Theres a 10mm nut each side ,4 in the front of the dash lower section ,sometimes behind the veneer trim ,depends on how old the car is.
Undo the steering column so it can be dropped slightly.
you can pull the wheel but I never bother.
You should now bew able to pull the dash towards you in an upwards movement.
Be careful as some cars have extra dash material under the windscreen rubber.
mercmad6.3 is offline
post #3 of 5 (permalink) Old 10-12-2007, 06:52 AM Thread Starter
g.w.b's Avatar
Vehicle: 300D
thank you for the help Marcmad6.3
S.A. ROCK
g.w.b is offline
post #4 of 5 (permalink) Old 10-12-2007, 04:22 PM
Quoted: 17 Post(s)
I just realized your car is listed as 300D. Is that a conversion or a 'South African version ' car?.
post #5 of 5 (permalink) Old 10-12-2007, 08:42 PM Thread Starter
g.w.b's Avatar
Vehicle: 300D
it is a conversion the 280se that was in Was to expensive to have it reaper so the previous owner did the conversion
S.A. ROCK
g.w.b is offline
Leathered dash board?? anyone with one there Peter Seow W126 S,SE,SEC,SEL,SD,SDL Class 15 04-04-2010 11:05 AM
dash board g.w.b W116 S, SE, SEL, SD Class 2 10-16-2007 01:12 AM
FS: Dash board Louie_D W126 S,SE,SEC,SEL,SD,SDL Class 0 04-17-2007 09:53 PM
dash board mrmati W124 E,CE,D,TD Class 2 03-14-2007 09:34 PM
Dash Board mazeeka R171 SLK-Class 0 06-29-2006 12:12 AM
