1965 300SE coupe - Page 2 - Mercedes-Benz Forum
post #11 of 25 (permalink) Old 10-02-2007, 08:32 PM Thread Starter
Date registered: Jul 2007
300SE rust repair
I hate to be the one, but can you provide any pictures? At this point I am going to need inspiration.
here is the update today. I bought the front crossmember after it got delivered I discovered there is an inner piece as well, so both will be installed on Saturday. I am going to post pictures of the progress.
ID:	144398   Click image for larger version
ID:	144399   Click image for larger version
jim dorociak is offline
post #12 of 25 (permalink) Old 10-03-2007, 03:43 AM
67300se5spd's Avatar
Date registered: Dec 2006
Vehicle: 2004 E320
Quoted: 10 Post(s)
Jim ,
That's the nitty gritty of it ! I've been there .....I had to replace the front crossmember on my 69 280 se once too.....due to rust.....Just be thorough and determined .
67300se5spd is offline
post #13 of 25 (permalink) Old 10-16-2007, 06:48 PM
Date registered: Oct 2007
Vehicle: 30+ mercedes and a suburban to tow them
Chris can be hard to reach some times. He does get a boatload of mail. He will respond eventually. Send him a welding photo; that will get his attention. He's got dozens of coupes and sedans. I think it's over 70 by now. -CTH
cth350 is offline
post #14 of 25 (permalink) Old 10-20-2007, 07:24 PM Thread Starter
Well, an update to anyone still reading this post. IT'S ALIVE. I changed the oil, reconnected the radiator, charged the battery and it started/ ran again. The fan is free spinning and never locking up to pull air through the radiator, so I shut it down just before it got hot. I need to address that change the oil and again new filter and run again I would like to run at least 1/4 tank of new gas to settle the engine in after not running for 25 yrs. Yesterday I noticed the oil change sticker in the door jam -- so -- the last know oil change was in 1979 mileage was 59,160 unbelievable that someone would drive a car like this and for some unknown reason just park it and forget it. Too bad they did not park it in the barn instead of the field.
Jim
post #15 of 25 (permalink) Old 10-20-2007, 07:44 PM
Vehicle: 2004 E320
Quoted: 10 Post(s)
Oh what a feeling !! Congratulations
post #16 of 25 (permalink) Old 10-21-2007, 01:08 AM
Date registered: Jun 2004
Quoted: 17 Post(s)
Is the fan electric or hydrualic? .It shouldn't have fan clutch like the later models,so the engine may not have been hot enough to start the fan.
mercmad6.3 is offline
post #17 of 25 (permalink) Old 10-21-2007, 11:08 AM Thread Starter
fan belt driven but freewheels, is not electric, and I can not tell from looking at whether or not it is viscous. I cleaned the hub then duct taped the fan and hub together with enough tape to hold and joint then I put zip ties to lock it all together. If anyone is reading and laughing, - for my test run it worked. I also realized why buying filters from dealer makes sense. It included the crush ring for drain plug, two crush rings for housing bolt on filter, and o ring. Jim
post #18 of 25 (permalink) Old 10-22-2007, 03:38 PM
Quoted: 17 Post(s)
post #19 of 25 (permalink) Old 10-22-2007, 03:40 PM
Quoted: 17 Post(s)
post #20 of 25 (permalink) Old 10-23-2007, 05:28 PM
Date registered: Aug 2007
Vehicle: Mercedes/BMW/Ferrari
you did check the coupler between the water pump and generator and have verified that it is not broken...mine was a 1967 but should be the same for 1965...
"I don't know anything for a fact",but have lots of opinions that might or might not pan out!
coastline is offline
    1969 Mercedes Benz 300SE 3.5 Coupe (W112) IN SELL! JoE_M Vintage Mercedes-Benz 18 09-13-2013 10:47 AM
    300se coupe interior light issue baltobenz Vintage Mercedes-Benz 1 04-15-2007 06:11 PM
    Just bought a 66' 300se coupe baltobenz Vintage Mercedes-Benz 19 03-31-2007 10:31 PM
    Just got a 64 300SE Coupe markus765 Vintage Mercedes-Benz 24 01-10-2006 09:52 PM
    300SE coupe mercnmini Vintage Mercedes-Benz 3 07-16-2004 08:07 AM
