1979 300SD Window Fell Down - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 09-19-2007, 07:23 PM Thread Starter
Date registered: Sep 2007
Hey guys, I've been somewhat lurking around here for awhile, I never hoped my first post would be me needing help.
But as the subject states, the power window in my W116 300sd fell down as i was trying to roll it up, I heard a clank of metal in the door and the window was completely uninterested in rolling back up. I took the door panel off and found a metal clip which im assuming is what tells the window to stay up and stop where it is or holds something that guides up. For now ive got a cardboard tube in there propping it up.
I can provide a picture of the clip of this would help, any suggestions to get this reinstalled and my window rolling back up?
The online manual I have didn't really tell me much for this, I'm thinking about investing in a hard copy if the internet falls through. Thanks in advance
sonicmase is offline
post #2 of 9 (permalink) Old 09-19-2007, 08:54 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 706 Post(s)
Include your pic of this clip with your post -- it couldn't hurt.
GeeS is offline
post #3 of 9 (permalink) Old 09-19-2007, 10:04 PM
peoples28's Avatar
Date registered: Nov 2006
I can tell you somewhat
The way i get power windows back up is to go inside the door. I take off the door panel which should slide forward or backward when u take off all the hardware. then go inside the door and youll find a bunch of bolts. I loosen all these bolts and then let the window back up, then i tighten all these bolts when it is up as far is it will go. THen i usually disconnect the power to the window by disconnecting the switch or if u see two wires with screws just take out the screws.
Hope this helps good luck.
peoples28 is offline
post #4 of 9 (permalink) Old 09-19-2007, 10:05 PM
peoples28's Avatar
bout the last post, i didnt read all the way through but if u had a pic id take a look
post #5 of 9 (permalink) Old 09-20-2007, 10:47 AM Thread Starter
Here's a picture of the clip, I can get any more pictures that anybody might want as well, feel free to ask if it helps you help me
<img src="http://i204.photobucket.com/albums/bb20/sonicmase/baneofmyday.jpg">
post #6 of 9 (permalink) Old 09-20-2007, 01:50 PM
79Mercy's Avatar
Date registered: Oct 2006
Vehicle: 1979 280CE
Quoted: 2 Post(s)
you forgot to put the pic in the IMG brackets.
'79 280CE with 226,000 miles
'76 240D 4 speed with 190,000
'85 300D Turbo with 266,000 miles
GONE but not forgotten
'76 300D with 195,300 miles
"83 300D with 174,000 miles
79Mercy is offline
post #7 of 9 (permalink) Old 09-20-2007, 03:15 PM Thread Starter
Well I have better pictures now anyway, fortunately I figured out the problem but I don't know if the clip just needs to be forced over that grove you can see on the bolt on the guiderail or what? Any ideas?
post #8 of 9 (permalink) Old 09-22-2007, 05:08 PM
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 706 Post(s)
That clip is included in P/N 123 720 01 14. The kit goes for $7.
GeeS is offline
post #9 of 9 (permalink) Old 09-24-2007, 06:53 PM Thread Starter
thanks guys, I actually got it all fixed up good as new
    wanded 1979 300sd window yonah.mt For Sale/Wanted/Trade/Giveaway 0 07-19-2007 03:12 PM
    wanded 1979 300sd window yonah.mt For Sale/Wanted/Trade/Giveaway 0 07-19-2007 03:10 PM
    1995 E320 - Window fell off the track, window motor still works. azo313 W124 E,CE,D,TD Class 3 08-06-2006 12:00 PM
    Rear window fell down abr W210 E-Class 13 02-18-2005 09:12 AM
    Question RE Interchangeable parts 1979 300SD - 1983 300SD Reedfarm W126 S,SE,SEC,SEL,SD,SDL Class 2 10-03-2004 08:03 PM
