My 280SE 4.5, your thoughts are appreciated! - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 09-10-2007, 07:13 PM Thread Starter
Peoria Benz's Avatar
Date registered: Jul 2006
Working on my '72 280SE 4.5.
I am looking at changing the shifter from the column to the floor.
Has anyone done this? Would appreciate any thoughts/ideas.
I will be stripping a stainless exhaust off another car and installing.
Car looks like hell; exhaust looks almost like new.
I got urethane bushings from Cox Racing Group.
Need to install & would like to consider other "mild" upgrades.
Would like to go to 16 inch wheels like the early 90's SL's.
Thoughts/etc. on this subject.
Additionally, I am parting out the above mentioned shifter donor.
Does anyone need anything?
It's not about the money. It's about the cars!
I love this forum.
Thanks in advance!
Peoria Benz is offline
post #2 of 3 (permalink) Old 09-10-2007, 11:31 PM
Date registered: Jun 2004
Quoted: 5 Post(s)
You need the steering column and the floor shift,along with the throttle position mechanism,reverse lock out wiring ( column cars sometimes have the firewall mounted switch) and shift rod for the trans. I don't think anyone has ever bothered because theres no real advantage.
Which bushes are you looking to replace? .Be careful when fitting stiffer bushes to the sway bars because the cars are designed to have a certain amount of roll,too little roll and you'll look like a ricer drift king. If the car is swaying too much into turns it maybe because the sway bar bushes have worn out. When were the shocks last replaced? . these cars are very forgiving when it comes to things like that and many owners are unaware that the car is'nt driving as well as it should.
mercmad6.3 is offline
post #3 of 3 (permalink) Old 09-11-2007, 04:19 AM
benzmizer's Avatar
Vehicle: 1983 240d AT; 1993 e320 AT
Quoted: 4 Post(s)
Jerry, post some pics.... GOOD LUCK!
benzmizer is offline
    any ideas appreciated Stubudd C208/A208 CLK-Class 7 07-10-2010 06:53 AM
    Help appreciated AntoN C. The Discount Tire Direct Tire, Wheel, Brake & Suspension 2 04-19-2007 05:39 PM
    please. input would be appreciated. mfprofile C208/A208 CLK-Class 5 02-27-2007 01:57 PM
    Help of any kind would be appreciated. Ninja500R General Mercedes-Benz 0 10-30-2006 10:21 AM
    2002 ML320 P/s whirl...any thoughts appreciated! s98swim W163 M-Class 5 10-22-2006 12:42 AM
