How to check condition of glow plug? - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 09-09-2007, 05:30 PM Thread Starter
benzfleet's Avatar
Date registered: Dec 2006
What is the proper way to check the condition of the 110 series diesel glow plug? These are from a 1966 200D. This is the style with large glow plugs and appears to have series wiring. AFTER I tried to check across a 12 volt battery without any results, I realized these plugs may not be suitable for 12 volts. THEN I read the fine print on the glow plug and see it is marked 0.9 V. I assume this is 0.9 volts.
Anyone able to tell ne how to properly test these glow plugs?
1973 280 W114 (Driver - 140,000 miles)
1974 280C W114 (Now running - driven off and on this summer)
1968 200D (Engine rebuild planned)
1964 200 (gasser parts car) & 1966 200D (complete car - Got to run. Now to see if clutch can be repaired.)
1980 300D W123 (Parts car - engine runs, but trashed)
1981 240D W123 4 speed ( In sad shape when bought - many parts from '80 300D has back on the road. Needs work, but shows promise.)
1988 300TE W124 (Does not run. 180,000)
benzfleet is offline
    Glow plug(s) or glow plug relay...? kavakava W123 E,CE,D,CD,TD,TE Class 16 03-04-2010 07:45 PM
    Check Engine/Glow Plug lights on EufaulaE300TD W210 E-Class 2 02-26-2007 05:10 AM
    Glow plug problems, no power to the glow plug relay kbbenz78 W123 E,CE,D,CD,TD,TE Class 8 11-15-2006 08:45 PM
    99 E300 Diesel - Glow plug and check engine light at the same time! dsellsbear W210 E-Class 4 03-05-2004 09:08 AM
