very rough idling - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 09-05-2007, 12:58 AM Thread Starter
madmanmerc's Avatar
Vehicle: 1970 250c, 300e amg
Quoted: 17 Post(s)
very rough idling
hey guys. when i turn the key on my 280c it takes about 30 seconds to start at first, then she idles like a harley, and when i let go of the gas, stalls. any inf would be greatly appreciated.
thanks
madmanmerc is offline
post #2 of 8 (permalink) Old 09-05-2007, 01:26 PM
Date registered: Jun 2005
Vehicle: 72 250 M130 W114
Check your timing. I just ran into the same problem. On my 250, I had to set it to 30' no vac 3000 RPM to get her to run right. Yours might be different so check your specks.
At idle she runs at 15' no vac. Very different from the 4 ATDC w/ vac on retard. Had the same problem you did.
ggenovez is offline
post #3 of 8 (permalink) Old 09-05-2007, 06:48 PM
Date registered: Aug 2007
Vehicle: W123 200D
Do you have to push the accelerator a LOT in order to keep her running? Is there any black or blackish smoke involved? If so, my first thought would be carburettor flooding over.
onre is offline
post #4 of 8 (permalink) Old 09-06-2007, 09:21 AM Thread Starter
madmanmerc's Avatar
Quoted: 17 Post(s)
timing was just done a few weeks ago. still same problem
post #5 of 8 (permalink) Old 09-07-2007, 03:12 PM
Don't want to beat a dead horse but did you use the procedure above for timing? Did yours come with US emmissions? are they working properly? When was the last time it ran properly, Anything change since then?
ggenovez is offline
post #6 of 8 (permalink) Old 09-07-2007, 10:51 PM Thread Starter
madmanmerc's Avatar
Quoted: 17 Post(s)
the timing was done by a real old schooler who worked on these inline sixes all his life, unfortunately he retired and lives in europe now
post #7 of 8 (permalink) Old 09-08-2007, 08:31 AM
Ok, I would double check, all you need is a timing gun, unplug the vacuum lines to the distributor, plug the vacuum lines (golf tees work very well for this), bring the engin up to 3000 RPM and point the timing gun to the timing marks.
According to the maintenance manual you should be reading 31-35'.
Before doing that check the dwell. that should be 30-40 if you have transistorized coil and 39-42.
You want to check the dwell first because a change in dwell is a change in timing.
ggenovez is offline
post #8 of 8 (permalink) Old 09-08-2007, 03:48 PM
peoples28's Avatar
Date registered: Nov 2006
id check the C
if its a 250 or 280 c that means that its carbuerated and not fuel injection
Id just check the carbuerator out, make sure the fuel lines and everything are clean. It sounds kinda like a fuel delivery prob
peoples28 is offline
    Rough Idling Question untouchable W163 M-Class 1 03-04-2007 09:22 PM
    ABS & rough idling keith@SG W124 E,CE,D,TD Class 1 02-01-2006 11:38 AM
    rough idling and stalling w124 aus W124 E,CE,D,TD Class 6 07-17-2005 01:56 AM
    rough idling nccong W140 S-Class 7 06-19-2005 11:09 PM
    Rough Idling patrick300TD W124 E,CE,D,TD Class 3 12-22-2004 04:33 PM
