Fuel gauge sensor - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 09-03-2007, 05:02 PM Thread Starter
benzfleet's Avatar
Date registered: Dec 2006
Fuel gauge sensor
I have worked out many of the issues for my '74 280C except the fuel gauge. The fuel level sender is damaged - I broke the fine wire on the sender. I do not know how to repair this and have not found a source to buy a sender.
Anyone repair one of these type senders? Know where to buy one? Have one to sell? Here in the middle of the backwoods, there are not many salvage yards with MBs to pick over.
1973 280 W114 (Driver - 140,000 miles)
1974 280C W114 (Now running - driven off and on this summer)
1968 200D (Engine rebuild planned)
1964 200 (gasser parts car) & 1966 200D (complete car - Got to run. Now to see if clutch can be repaired.)
1980 300D W123 (Parts car - engine runs, but trashed)
1981 240D W123 4 speed ( In sad shape when bought - many parts from '80 300D has back on the road. Needs work, but shows promise.)
1988 300TE W124 (Does not run. 180,000)
benzfleet is offline
post #2 of 4 (permalink) Old 09-03-2007, 05:14 PM
79Mercy's Avatar
Date registered: Oct 2006
Vehicle: 1979 280CE
Quoted: 2 Post(s)
I found one: Your Parts Search Returned 2 Part(s))
'79 280CE with 226,000 miles
'76 240D 4 speed with 190,000
'85 300D Turbo with 266,000 miles
GONE but not forgotten
'76 300D with 195,300 miles
"83 300D with 174,000 miles
79Mercy is offline
post #3 of 4 (permalink) Old 09-06-2007, 06:53 PM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 95 Post(s)
Look at Adsit Company, Inc. | New, used and rebuilt parts for Mercedes Benz automobiles as well. I've had a lot of good luck with these folks. The actual swap-out is really easy...
Grubeguy is offline
post #4 of 4 (permalink) Old 09-06-2007, 07:34 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 544 Post(s)
We have brand new fuel sending units for $99 (the same one advertised above for $130). Just call or PM if you're interested and we'll be happy to set you up. That said, good luck on saving the money and repairing your unit -- a better way to go if you can manage it.
GeeS is offline
    Faulty Fuel Gauge or Fuel Sensor MB9900 W124 E,CE,D,TD Class 8 05-05-2013 07:51 PM
    Changed my fuel pump to fix my fuel gauge, and got an added BONUS. mikewired W163 M-Class 15 03-04-2012 08:52 AM
    Fuel gauge sending unit / sensor Leeyore W123 E,CE,D,CD,TD,TE Class 9 07-18-2006 01:40 PM
    Problems fitting 500 fuel gauge-oil pres'-water temp gauge cluster to 560 clocks mutley666 W126 S,SE,SEC,SEL,SD,SDL Class 2 10-10-2005 09:03 AM
    Update on Fuel Gauge Problem: Got Fuel Pump Replaced Today tjhsiao W163 M-Class 4 10-25-2002 04:47 PM
