1973 280C Occasional Smokey Ride - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 08-15-2007, 10:07 PM Thread Starter
Date registered: Aug 2007
I purchased my 73 280C about six months ago and it was in pretty good condition. When I first purchased it I had no smoke problems whatsoever. I had some general tune-up work done to it, including a new fuel pump. After the new fuel pump was installed I began to have time-to-time exhaust smoke issues. The smoke usually only happens if 1) I idle the car for over two minutes and then when I accelerate it kicks off smoke or 2) if I drive at 50-55 mph for a bit and then stop when I go again it'll kick up a good amount of smoke. The color's a bit hard to characterize - I wouldn't say it' black but I wouldn't say it's white either. Greyish is the best description. That's how it generally kicks smoke although sometimes it seems to have a mind of it's own and it'll just throw some smoke on acceleration or after a routine quick stop sign. Also, the car is not eating excessive oil, although I do have an occassional leak on start-up if I rev the engine high. Do I need to readjust my carb b/c of the new fuel pump? Or are there other considerations? O/w the car runs and looks great - I would love to solve the embarrassing problem. Suggestions?
VintageOwner is offline
post #2 of 3 (permalink) Old 08-16-2007, 09:27 AM
benzitch's Avatar
Date registered: Oct 2003
Vehicle: 91 560SEC Beryl/Palomino 91 420SEL Black Pearl/Mushroom 89 420SEL Ice Blue/Navy 88 420SEL 94 E320
Quoted: 106 Post(s)
Sounds like the diaphram for the break booster. It is rubber and gets hairline cracks, causing the engine vacum to suck in some brake fluid.
It was an easy fix.
I have a 73 280c and it ran fine just smoked from time to time as you explained.
Bruce
BENZITCH
Bruce
benzitch is offline
post #3 of 3 (permalink) Old 08-16-2007, 03:28 PM Thread Starter
Thanks Bruce, I appreciate it - it's frustrating when the ride is great but for a little smoke -
    Help! 1973 280c benzdealersj Vintage Mercedes-Benz 3 03-30-2007 11:21 AM
    1973 280C head lights baker462 Vintage Mercedes-Benz 7 03-20-2007 07:39 PM
    1973 SL & 1973 280C His & Hers jtbenzman1 Vintage Mercedes-Benz 0 02-24-2005 10:30 AM
    1973 280C Lower Oil Pan gasket still leaking.... doc_rage Vintage Mercedes-Benz 2 10-27-2004 03:23 PM
    84 380 sl occassional Oil burn? jlb.0922 General Mercedes-Benz 2 04-23-2004 08:42 AM
