108 Driver's Vent window - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 08-02-2007, 03:22 PM Thread Starter
Date registered: Jun 2007
Vehicle: 1992 300TE 4Matic, 1987 560SL, 1985 300SD
Question 108 Driver's Vent window
Hi All,
I recently purchased a 68 280SE. The driver's vent window was broken, for lack of the proper term, at the little bullet looking piece that holds the top in place. I purchased a replacement window - which turns out to be the wrong tint - and removed the broken vent window. How does one remove that bullet looking piece so that I can put the new vent window in?
Additionally this vehicle is missing the radio antennae which should be passenger side front fender mounted. How does one replace that missing antennae?
I appreciate any and all assitance.
Dave H...
DaveH is offline
post #2 of 2 (permalink) Old 08-03-2007, 01:57 PM
Date registered: Jun 2006
Vehicle: 1981 300CD, 1973 280C
With the right front of of the car jacked up and the front wheels turned to the right, you will see an access cover held in place with 8 mm? screws inside the wheel well. Remove that cover, clean out the mud and leaves and then you will see the rest of the antenna! Any reputable auto glass shop can advise on the vent window issue.
carnut1 is offline
    Dead Driver's window MylesC C208/A208 CLK-Class 0 03-02-2007 08:53 PM
    driver's side window ravioliiiii W163 M-Class 2 02-10-2006 06:25 PM
    Break In Driver's window gone. MLBULL Detailing and Car Care 2 10-29-2005 09:13 PM
    Ticking Noise From Driver's Air Vent kutz W140 S-Class 5 10-09-2005 01:59 PM
    grease on driver's window HELP sgjacob@patmedia.net W163 M-Class 9 08-10-2004 12:11 AM
