rear end gears (w111) - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 07-29-2007, 12:25 AM Thread Starter
Date registered: Jun 2007
Vehicle: 1964 220 S Finnie
Send a message via AIM to johnnyIXI
is there a longer geared (or do the make gear kits?) rear end for the W111 sedans? 1st is so short and 4th feels like Im winding out on the highway (of course I wouldnt know theres no tach).
1964 220 S Fintail (sunroof) Cardomain
1963 Ford Fairlane 500 Sports Coupe Cardomain
johnnyIXI is offline
post #2 of 8 (permalink) Old 07-29-2007, 04:20 PM
Yes, Use the W108 automatic transmission rear,
You also get rear discs,
Very good update, Replace all the rubber parts and pinion seal while you are there.
(need one? got one)
Brian O
bostosh is offline
post #3 of 8 (permalink) Old 07-30-2007, 03:29 AM
wbain's Avatar
Date registered: Dec 2003
These cars are so underpowered that the gearing is very low. At 60 mph the engine is turning about 3500 rpm. This is normal and you don't need to worry. My W126 300SE turns 3000 rpm at 60 mph.
If there is vibration, check the driveshaft u-joints, center bearing and flexdisc. Alos, don't forget to grease the driveshaft and the swing axle joint on the differential. The car should be very smooth. Check and/or the engine and trans mounts as well as the rubber bushings in the rear axle training arms and lateral support.
Please check this posting for a look at bad suspension bushings.
M-100 Message Board - 6.3 Rear Suspension
The car displayed has air suspension and a slighjtly different setup.
wbain is offline
post #4 of 8 (permalink) Old 08-01-2007, 01:16 PM
Vehicle: 2005 SL 55 "k" 26K 1967 250 SL ?K 1984 500 SEC 242K http://www.flickr.com/photos/mercebman/
Quoted: 15 Post(s)
(need one? got one)
What is the ratio? is it out of a 4.5?
hilld is offline
post #5 of 8 (permalink) Old 08-01-2007, 07:24 PM
Yes, it is from a 4.5,
ratio is what came original 3.23?
maybe? unconfirmed.
Brian O
bostosh is offline
post #6 of 8 (permalink) Old 08-01-2007, 09:53 PM Thread Starter
How much? Email me Im interested. Will you include the power brake valve needed for the rear disks?
post #7 of 8 (permalink) Old 08-02-2007, 09:04 AM
rear axle assembly
I have options, do you want the 4.5 rear axle OR the 280SE automatic rear axle? I have not counted the revolutions to confirm ratios yet. From memory now, the original 220S (standard trans) was a 4.10, the 280SE (automatic) is 3.70, the 280SEL 4.5 (automatic) is 3.23.
Yes, I have a compensating valve. I have the entire 280SE 6cyl car for sale cheap. The 4.5 axle is more valuable to me. (Spare for my 64' 220SEc)
Email bostoshx@adnc.com, ph# 619-200-7203
Brian O
bostosh is offline
post #8 of 8 (permalink) Old 08-13-2007, 09:12 AM
Date registered: Oct 2006
Vehicle: 1967 250SE (German market coupe, 4sp sunroof), 2000 Europa G500 (early model)
In my 4sp manual 250SE (with a 280SE engine) going from the stock 3.90? 4.10? diff to the 4.5 rear improved the car more than any other modification I've made.
Strangely acceleration seems to have not suffered at all (in fact it may have actually improved!) and all around driveability is much much better. The 280 makes more noise than power wound up and the steeper gearing better utlizes the broad torque curve.
Of course with an automatic or a different engine this may all be different...
Bill
wcelliot is offline
    W111 mechanical fuel injection cold start 1963 W111 220 SEB MercedesOtto Vintage Mercedes-Benz 1 07-29-2007 04:29 PM
    Looking for w111 Coupe front end sheet metal Autobahnfahrer For Sale/Wanted/Trade/Giveaway 0 12-08-2005 09:12 PM
    W111.021 compensator spring and rear end noise grezm0nkey Vintage Mercedes-Benz 1 02-03-2005 06:27 AM
    ''DEWDALTZ can you show me a picture of your rear view camera from the rear end of the car alroumi W163 M-Class 3 01-26-2005 08:32 AM
    Dreaming of high gears........now im wishing for any gears!!!! peter G-Class 5 05-14-2002 04:22 AM
