Standed 300miles from home!!!Bearing issue - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 07-21-2007, 09:56 AM Thread Starter
Vehicle: 300CE-24 -91
The rear end suddenly started to shake and when I pulled over the rim was really hot. I suspected binding brakes and took the wheel off, brakes were fine but I can move the wheel quite a bit side/side, it also makes a clonking noise from the hub when I do that.
I´m really far from home but I do have some tools, is there a way of adjusting the bearings? From the outside it looks like the bearings are not tapered but I really hope that I´m wrong.
What can I do?
MPalm is offline
post #2 of 5 (permalink) Old 07-21-2007, 03:51 PM
Richard 220Sb's Avatar
Date registered: Jun 2006
Vehicle: 1964 220Sb Fintail
I'm no expert but there's no local garage/mechanic to help ? Good luck hope it is sorted.
(Is the bearing properly greased?)
Richard 220Sb is offline
post #3 of 5 (permalink) Old 07-21-2007, 07:48 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 733 Post(s)
Rear wheel bearing is not tapered. If the hub is damaged, you're probably better off picking up a good used rear control arm. Good luck!
GeeS is offline
post #4 of 5 (permalink) Old 07-22-2007, 06:59 AM Thread Starter
I managed to loosen the driveshaft enough to look at the backside of the hub. There was a big slotted nut that had become loosened and I could tighten it with a screwdriver and a hammer.
That was enough to take me home!!!
How do I get to the bearings?
I still feel like I should check them out, just to be on the safe side.
MPalm is offline
post #5 of 5 (permalink) Old 08-04-2007, 08:17 AM Thread Starter
Finally I got the time to start looking at this bearing thing. I have some problems already:
1. how do I get the driveshaft out from the diff? Seems like there´s not enough room to pull it out, do I have to take off the shock and push down the control arm?
2. How is the hub attached to the control arm, obviously there´s the big nut with four slots in it at the inside, but is that all that holds it together?
3. Are the bearings pressed on the hub or in the control arm (outer race)?
MPalm is offline
    Radio Harness issue, Tuner issue DamianC R170 SLK-Class 1 08-28-2006 06:46 PM
    Brake-light issue leading to BAS/ESP issue??? Isoplus R170 SLK-Class 7 06-17-2006 12:57 PM
    Release Bearing briandrake G-Class 6 06-05-2006 03:15 AM
    bearing kits 4x4abc G-Class 5 02-04-2006 03:34 AM
    Bearing in mind....... ThrillKill C208/A208 CLK-Class 6 08-24-2005 01:30 PM
