6.9 suspension conversion - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 07-20-2007, 03:00 PM Thread Starter
Date registered: Oct 2006
Looking for someone that has swaped out the hydraulic for standard spring & shock set-up. I know there's a few out there. Would appreciate you help. Thanks.
john erbe is offline
post #2 of 7 (permalink) Old 07-22-2007, 09:33 PM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 103 Post(s)
I've not done it, but my father did. It's doable, and relatively easy. Shall I get more info? You'll need a junked 108 for the suspension stuff.
Grubeguy is offline
post #3 of 7 (permalink) Old 07-23-2007, 07:54 AM
could that possibly be a junked w116?
I have a complete junk W108 up on Ebay cheap
bostosh is offline
post #4 of 7 (permalink) Old 07-23-2007, 10:25 AM
Grubeguy's Avatar
Quoted: 103 Post(s)
Nope, a 108. It was one I wrecked for him when I was 16. He was tired of messing with the air bags, the lines, the air compressor (and tired of trying to find leaks), so he took the guts of the wrecked car, and put them into his 300SEL. The local Benz guru about puked, as it turned the car into a 6.9 powered 280SEL. Aside from the wood interiors, the suspension system, the engine and a few other doo-dads, the cars are essentially the same chassis.
Grubeguy is offline
post #5 of 7 (permalink) Old 07-23-2007, 10:49 AM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 734 Post(s)
^ I'm guessing that you've confused a 6.3 with a 6.9. The thread-starter in this case, will require a w116 chassis. Much better to repair the car as is, IMHO.
GeeS is offline
post #6 of 7 (permalink) Old 07-23-2007, 12:01 PM Thread Starter
Correct, confusing the two. For all you guys that say repair the original hydraulic, you can probably afford to keep putting money into the suspension, I can't.
post #7 of 7 (permalink) Old 07-24-2007, 12:12 PM
Grubeguy's Avatar
Quoted: 103 Post(s)
Aha! I should read the thread title more closely!
Grubeguy is offline
    6.9 suspension conversion john erbe W116 S, SE, SEL, SD Class 9 07-20-2007 03:08 PM
    couple of pics with complete AMG suspension conversion. samm W140 S-Class 12 03-09-2007 04:32 PM
    Suspension conversion mission accomplished - strut installation details. fgwinn R171 SLK-Class 7 02-02-2006 08:10 PM
    S500 suspension conversion Turntablist General Mercedes-Benz 7 09-06-2005 05:00 AM
    Help: 300E Sportsline Conversion (suspension upgra Guest (MBNZ) W124 E,CE,D,TD Class 1 04-10-2001 06:26 PM
