removing starter - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 07-18-2007, 12:09 PM Thread Starter
Date registered: Jun 2006
removing starter
how do you take of the starter on w115 i seemed to have taken off every bolt but it still wont budge do i have to take off the motor mount bracket too?
W208 2002 CLK 430
05 E320 CDI
previous MB: W126, W115, W124
Maksiu420 is offline
post #2 of 2 (permalink) Old 07-19-2007, 07:05 AM
Date registered: Jun 2004
Quoted: 17 Post(s)
There should be the two large, long socket-head bolts that go through the bell housing into the starter nose (which surrounds the starter drive and mounts the solenoid), the small wire on the solenoid, and the large battery cable on the solenoid. It is possible there is another brace between the starter (opposite the starter drive) and the engine oil pan, but probably not likely on that model. It should fall right out then.
KCM is offline
    New starter? BenzToy R/C107 SL/SLC Class 9 04-01-2007 09:53 PM
    Removing starter '93 2.3 slk230red W201 190-Class 10 01-25-2007 05:53 AM
    Starter Big D W126 S,SE,SEC,SEL,SD,SDL Class 3 10-20-2003 12:19 AM
    280ge removing engine without removing auto trans toka G-Class 8 09-17-2003 05:56 AM
    help removing the starter motor Guest (MBNZ) W123 E,CE,D,CD,TD,TE Class 0 08-08-2002 05:03 PM
