Fintail Maintenance & Replacement - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 07-16-2007, 07:14 PM Thread Starter
Richard 220Sb's Avatar
Date registered: Jun 2006
Vehicle: 1964 220Sb Fintail
I dont know exactly where to post this thread but here goes.
Fintails are 40+ years old now and when I bought mine like most there was an obvious need for immediate work on body and engine.
That now done and some 8,000kms later its time to look at the rest of the car. I would like to extend my touring range and head further from home. Nothing is broken as such (so why touch it... I can laugh at myself...) however what are the other sensible part replacement modifications to ensure ongoing safe and reliable driving? I currently drive 5-600kms a day so a breakdown at the farthest point would be 'inconvenient' at best. I also intend to keep the car for a number of years.
What is the service life of ball joints? If I replace the shocks are there other pieces I should renew at the same time to save time and money at a later date? What about wheel bearings, not knowing if/when they have been previously replaced, what is a sensible working life? Likewise if I replace bearings is there anything else I should consider at the same time?
Is there a thread of separate forum on servicing tips for older Mercs along these lines? Any good (easy to follow) Merc books out there?
Thanks any practical advice !
Richard 220Sb is offline
post #2 of 3 (permalink) Old 07-17-2007, 05:21 AM
wbain's Avatar
Date registered: Dec 2003
Welcome to our little corner. I too have a 220S, a 1965, and I'm going through it right now.
First of all, the car has kingpins not ball joints. As long as they are properly greased they will last a long time. I have a grease gun with a flexible hose and I'm using Mobil ! synthetic grease. The key, is grease the joints, every moving joint has a grease nipple. The kingpin gets greased on the backside of the upright tube.
There are also two grease points on the driveshaft and two on the lower swing axle joints. Check the rubber cuff between the differential housing and the swing axle.
Make sure the brake hoses are new. Proper flare nut tools are required to undo the brake lines from the hoses. Check the rear brake shoes and cylinder for proper operation. The Ponton web site has lots of good info about this.
Mercedes-Benz Pontons (1953-1962)
Mercedes-Benz Ponton Workshop
If you have trouble passing grease through any joints, use a heat gun to soften the grease inside the joint, especially inside the kingpin tube. The other models of the same time also use the same suspension and there is allot of info out there. The m100 board has good tips,
M-100 Message Board
the pagoda forum also has good info.
Pagoda SL Forums
Get a repair manual as well. One thing I found out is that the W111 shop manual leaves out some info that is in the Ponton shop manual, i.e. the 190 and 220 shop manuals, I'm talking Ponton manuals. Get the spare parts table from MB as well, these show assembly view drawings of the car.
The Russian web site has many models.
Russian Web Site
spefically for the W111 220S
220S Spare Parts
wbain is offline
post #3 of 3 (permalink) Old 07-20-2007, 04:38 PM Thread Starter
Many thanks the great response. I had the nipples greased about a year and 4,000kms ago so they should still be in good order but I guess no harm in an annual squirt.
Wear and tear is an issue and I'm focusing on replacing rubbers at the moment, engine mounts, exhaust mounts, transmission and everything else as I go along. The car is riding much more smoothly as a result which in itself reduces wear and tear.
I've been around most of the sites you mention already, they're all good but it seems so difficult to exract servicing/replacement advice of the kind I'm looking for from the plethora of general good advice!
I shall keep pressing on !!
    Brake Maintenance / Pad replacement (2005 230 Sport) BF_JC230 W203 C-Class 8 11-24-2009 12:06 PM
    Maintenance & Repair Manuals Mycroft19 W126 S,SE,SEC,SEL,SD,SDL Class 1 07-09-2006 05:04 PM
    my fintail pontiac Vintage Mercedes-Benz 29 01-17-2006 10:35 AM
    W111 Fintail interchanges? FinnyFiend Vintage Mercedes-Benz 1 02-02-2004 02:13 PM
    Anyone else got velour seats?. Help sought on maintenance & cleaning shrimpton Detailing and Car Care 1 11-20-2002 01:12 AM
