diaphram replacement - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 07-15-2007, 11:31 AM Thread Starter
Date registered: Mar 2007
i want to replace the diaphram in my ip on a 74 240d, i have looked it over and was wondering if the parts on the back of the pump come off individuly or as an assembly. on the very back is a piece with two screws holding it on then a peice with four screws and finally another with four screws do you need to remove these one at a time or just the one with the diaphram in it. also which one contains the diaphram. any help is appriciated.
smokydog is offline
    i.p. diaphram smokydog Vintage Mercedes-Benz 4 05-03-2007 05:56 AM
    Replace vacuum pump diaphram or not joeschmoe W123 E,CE,D,CD,TD,TE Class 2 06-25-2006 08:59 AM
    AC Replacement hubsocket W126 S,SE,SEC,SEL,SD,SDL Class 18 02-21-2006 04:13 PM
    Replacement for the "G"? amzimmy G-Class 6 12-18-2003 04:39 PM
    SLK 230-2001 tire replacement/brake pad replacement Guest (MBNZ) The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 03-09-2002 10:08 PM
