Hmmm Reverse hard to find - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 07-14-2007, 03:32 PM Thread Starter
Date registered: Jul 2007
I have a new(to me of course) 1966 200D with floor shift 4 speed. The shift linkage was really, really sloppy so reverse was very hard to find. I could, with persistence and serious left leaning pressure, eventually find it within a few minutes.
So I made a HUGE mistake: I ordered a set of bushings and fixed it. Now reverse is GONE. Gears 1 thru 4 are now tight and sure and true the car shifts like new when going forward. Except now reverse is impossible to find - It just isn't there. I think I could probably find it the old way - but I am subconsciously reluctant to put so much pressure on it now that I see how the linkage worked and realize you shouldn't have to put pressure on this.
I really think I will have to drop the transmission and look at the shift rails and forks. Anyone have any thoughts, experiences, guidance that would help me avoid this? Even a "Hey dummy, you have to push down to get in reverse" would be welcome right now!
Thanks a million in reverse - oops, I mean in advance ,
NCDiesel
NCDiesel is offline
post #2 of 3 (permalink) Old 07-15-2007, 08:28 AM
Does this transmission have external shift linkage . All my mercs are auto. Although I am seasoned auto tech and have ran into this on other makes so what has hapened in the past is the external linkage gets tweaked or bent the sloppy bushings allow you to find reverse howevever with extreme effort. replacing the bushings restores the geometry of the linkage making it more difficult or impossible to find reverse(or whatever gears are affected) hope this is helpful. DOUG CONYER ASE MASTER TECH
arthrdgls is offline
post #3 of 3 (permalink) Old 07-15-2007, 08:53 AM Thread Starter
It is external linkage. I thought the same thing(slightly bent linkage), so I used the shift linkage out of my parts Benz just in case and no go. Same problem. While the linkage was disconnected I tried to find reverse manually and couldn't find it by manipulating the shift lever that protrudes from the tranny cover. It is hard to manipulate though, so it may have just been that I did not have the strength/leverage to do it.
Thanks for the reply - I appreciate it.
NCDiesel
NCDiesel is offline
    Hard to get reverse, Help my S500!!! markh827 W140 S-Class 7 01-11-2007 07:46 PM
    Hard to find wepowe W126 S,SE,SEC,SEL,SD,SDL Class 8 01-01-2007 02:07 PM
    hmmm a find? LarryD. W126 S,SE,SEC,SEL,SD,SDL Class 11 05-08-2006 09:56 AM
    hmmm where do i find wheel locks???? izzodesh W126 S,SE,SEC,SEL,SD,SDL Class 5 06-25-2003 01:35 AM
    Stumped my mechanic! Hard wet/damp start - engine reverse?300e jhoising W124 E,CE,D,TD Class 1 10-10-2002 09:36 PM
