Lowering w115 - Mercedes-Benz Forum
post #1 of 27 (permalink) Old 07-08-2007, 05:10 PM Thread Starter
Date registered: Jul 2007
Question Lowering w115
Hi guys,new here.Any suggestions for lower suspension kit for w115?
heavybone is offline
post #2 of 27 (permalink) Old 07-08-2007, 08:56 PM
wbain's Avatar
Date registered: Dec 2003
No suggestions at all. These cars really shouldn't be lowered. You could first start by replacing all the rubber mounts, front subframe mounts, rear trailing arm and diff. moujnts, replacing the ball joints, tie rod ends, seal your steering gear.
Next, replace the brake hoses and make sure the master cylinder is not leaking. The driveshaft flex discs and U-joints need inspecting and replacing. From there, find some thicker sway bars to improve your handling. New Bis=lstein shocks to take advantage of all the improvements you've made. Next, get wider wheels and tires for even better handling.
If you have a gas version, overhaul the engine or even replace it with a newer one. If you have a diesel, get a recent turbodiesel engine.
wbain is offline
post #3 of 27 (permalink) Old 07-08-2007, 10:35 PM
4.5_sport's Avatar
Date registered: Apr 2004
Vehicle: 1994 E320T, 1979 VW Rabbit
Send a message via MSN to 4.5_sport
Lower it.
I had a spring shop wind some springs for mine. I have a W108 280SE 4.5 lowered 3 inches running 18X8 wheels. It handles and rides very well.
4.5_sport is offline
post #4 of 27 (permalink) Old 07-09-2007, 07:05 AM
benzmizer's Avatar
Vehicle: 1983 240d AT; 1993 e320 AT
Quoted: 4 Post(s)
4.5_sport, post some pics!
Here's a W115 using airbags....
Viva la Raza!!!
benzmizer is offline
post #5 of 27 (permalink) Old 07-09-2007, 08:57 AM
4.5_sport's Avatar
post #6 of 27 (permalink) Old 07-09-2007, 09:14 AM Thread Starter
Thank you so much for your help wbain & 4.5 sport( you have a GREAT W108),i want to fit 8x16 and make it look like lowrider(without airbags,i'll post a pic to see what i mean) with less work...
Wbain do you have any idea if i can make it 4matic? (a w202-300-4matic maybe???)
post #7 of 27 (permalink) Old 07-09-2007, 10:18 AM
z168's Avatar
Date registered: Oct 2005
Vehicle: M62
Quoted: 88 Post(s)
the classic models are very hard to modify without it looking ricey. this one you just pulled nicely
Deutsche Tourenwagen Meisterschaft
z168 is offline
post #8 of 27 (permalink) Old 07-09-2007, 03:50 PM
Date registered: Jun 2004
Quoted: 17 Post(s)
Do you want looks ( lowering) or decent handling ( 4 matic) .If you lower your W115 you will not get both.believe me I have had lowered W114's and they are an absolute dog to drive in a normal situation.( rubbing tires,bottoming suspension banging underneath)
Terriffic handling is easily obtained by reconditioning all the suspension joints,with more modern adjustable shocks and fitting the Euro rear sway bar.It bolts in .
Want to get even better handling? source a back end from a W107 with anti dive links and bolt that in.
larger diameter wheels will connect with inner wheel house panels,and probably remove any good handling characteristics if lowering is still waht you desire..When new the German ( and other markets) had the 280E which will run to 130MPH on exactly the same suspension....and drive remarkebly well .If you could run that fast in your area, why would you want to spend the time and money converting to a 4 matic ?
In fact, if you want better handling buy a 190E .
mercmad6.3 is offline
post #9 of 27 (permalink) Old 07-11-2007, 12:45 PM Thread Starter
It was my father's favorite car (my father recently died) and i want to keep it for myself.I don't have much experience with oldtimers and that's why i'm asking all these silly (to most of you) questions.I'm trying to make it better because my father didn't used since 2002 so i'm looking for suggestions to improve it.Thank you for being helpful guys!
post #10 of 27 (permalink) Old 08-16-2007, 12:53 PM
76'benz-ford-chev's Avatar
Vehicle: 1976 300d Mercedes Benz
Send a message via AIM to 76'benz-ford-chev
I can look up the url to this guy that was going to make me springs for my car and i wanted to lower my just a little like .5 to 1 inch. i go looking for it but the car handles fine just needs sway bars and rubber joints.
1983 Toyota 4WD SR5 All Stock D-D 108K
(Making Page)
1996 Chevy Lumina LS Stock With Rebuit Engine 100K
Luminas Page
1976 Benz 300D With 302
Benz's Page
My Old BMW's Page(He's A Cube Now.......)
76'benz-ford-chev is offline
    Help Please, w115 300D smemolo For Sale/Wanted/Trade/Giveaway 0 12-18-2006 11:38 PM
    W115 parts vlb716 Vintage Mercedes-Benz 2 08-22-2005 12:26 AM
    W115 250CE? Must I try? CHINCHE W123 E,CE,D,CD,TD,TE Class 6 12-28-2004 01:36 PM
    Question about W115 CHINCHE W123 E,CE,D,CD,TD,TE Class 2 03-26-2003 11:34 AM
    W115 Guest (MBNZ) W123 E,CE,D,CD,TD,TE Class 1 05-30-2002 01:00 AM
