78 240D Shift Problem - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 06-30-2007, 01:32 PM Thread Starter
Date registered: Jun 2007
I had a problem with the engine shutting off and after much research (with help from this forum) fixed the vacuum so it turns off promptly.
It appears I have created another problem with the kick-down on the automatic. It wants to slip if I force a kick-down. If I simple manually down shift no slippage. Further research pointed to a common vacuum modulator problem with leaks or adjustments needed... One problem I can not find a vacuum modulator on this transmission. I also can not find the location of any other components controlling this problem.
Any suggestions on resources? Thanks
oldyella is offline
    FS Well Worn 81 240d stick shift Cobb2 For Sale/Wanted/Trade/Giveaway 6 04-04-2007 03:57 AM
    Euro 240D manual shift limo smallfence W123 E,CE,D,CD,TD,TE Class 12 10-22-2006 05:44 PM
    240D auto wont shift into 4th vtharpe W123 E,CE,D,CD,TD,TE Class 2 07-08-2005 05:48 AM
    77 240D Automatic will not shift ??? ELRUBIO W123 E,CE,D,CD,TD,TE Class 2 02-26-2004 06:36 PM
    83 240D tranny won't shift - unless I let off the gas each gear Guest (MBNZ) W123 E,CE,D,CD,TD,TE Class 2 03-02-2002 07:15 PM
