coolant hose to nowhere on w115 - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 06-21-2007, 02:27 PM Thread Starter
Date registered: Jun 2006
i was trying to find the coolant resorvoir when i followed the line from right underneath the radiator cap and found that it lead nowhere simply pointed down towards the ground underneath am i missing a piece or is it designed like that? and how do you check the coolant level on these cars? what kind should go in (74 240d engine 68 220d body)
Maksiu420 is offline
post #2 of 2 (permalink) Old 06-21-2007, 05:29 PM
wbain's Avatar
Date registered: Dec 2003
There's no coolant reservoir on these older cars. That line is a overflow vent. To check the coolant level, remove the radiator car but not when it's hot. You can get burned.
wbain is offline
    Can anyone ID a coolant hose? HughF W201 190-Class 5 01-01-2007 08:50 AM
    Coolant Bypass Hose jrehm W123 E,CE,D,CD,TD,TE Class 7 10-11-2006 08:47 PM
    Help w/Coolant Hose Replacement Teutonic R/C107 SL/SLC Class 4 06-26-2006 10:16 AM
    Cracked coolant hose? Professor Booty W124 E,CE,D,TD Class 1 04-08-2005 07:12 AM
    Coolant Hose Failure ByByeAmericanPie R170 SLK-Class 2 05-04-2004 06:34 PM
