Solex PDF's for the carb people. - Page 2 - Mercedes-Benz Forum
post #11 of 19 (permalink) Old 03-21-2011, 07:58 AM
Always's Avatar
Date registered: Feb 2010
Vehicle: 1975 MB 280 sedan - automatic
Amen - I would love to see these PDFs too!
Always is offline
post #12 of 19 (permalink) Old 03-21-2011, 08:17 AM Thread Starter
Boring Cars...meh!
Nutz 4 Benz's Avatar
Date registered: Aug 2005
Vehicle: 81 280E, 84 500SEC, 87 560, 89 "300E", 91 500SL, 15 E350 4Matic Estate, 71 BMW 2002, +others
Quoted: 17 Post(s)
Yeah, that PDF host sucked. I no longer have this information, sorry.
http://i30.photobucket.com/albums/c328/nutz4benz/W123/6C3A9CA5-EDFF-4834-8125-34B70B20A676_zpsiyesrawz.jpg
Nutz 4 Benz is offline
post #13 of 19 (permalink) Old 06-12-2011, 03:44 AM Thread Starter
Boring Cars...meh!
Quoted: 17 Post(s)
Trying again. 1st main PDF file is larger than benzworld will allow, so I'll try to get it up later, plus more. If you have a specific section you need, let me know in this thread.
post #14 of 19 (permalink) Old 06-12-2011, 04:02 AM Thread Starter
Boring Cars...meh!
Quoted: 17 Post(s)
Starting device (choke)
I need to host Adjusting Choke, as it was too large as well.
File Type: pdf Solex11_Testing_Pulldown_Diaphragm_For_Leaks.pdf (183.3 KB, 136 views)
File Type: pdf Solex12_Removal_and_Installation_Of_TN_Choke.pdf (175.5 KB, 114 views)
File Type: pdf Solex13_Removal_and_Installation_OF_Choke.pdf (658.4 KB, 129 views)
File Type: pdf Solex14_Checking_and_Correcting_Choke_Housing_Mark.pdf (368.3 KB, 135 views)
File Type: pdf Solex15_Checking_Choke_Cover_Stepped_Heater.pdf (1.56 MB, 173 views)
File Type: pdf Solex16_Istallation_Of_Choke_Cover_Stepped_Heater.pdf (211.9 KB, 119 views)
post #15 of 19 (permalink) Old 06-12-2011, 03:07 PM
Always's Avatar
Thank you!
Always is offline
post #16 of 19 (permalink) Old 10-12-2011, 09:52 AM
Date registered: Aug 2011
Vehicle: 1973 280 w144 m110
BIG THANK YOU!!!
Jonny D is offline
post #17 of 19 (permalink) Old 01-11-2015, 10:13 PM
Date registered: Apr 2006
Yeah Thanks for posting, was invaluable recently as i had a problem with my 280s.
I have read everywhere about the carb warping , and true enough , every solex i have stripped down has been majorly warped.
Though most people blame this on an ongoing overtightening of the four mounting studs, I think its also the overtightening of the central airfilter housing. This pulls up the centre of the carb and all the carb bodies show it warping from the centre up which supports this theory.
If your solex is only warped a few mm, I have wondered if the centre hole for the filter housing stud could be drilled out from bottom baseplate
and up to it meets the center stud thread allowing a bolt to be screwed in from the base pulling the carb body back down clamping it to base plate,
If the bolt was the correct length it would still allow the filter housing stud to screw home. This combined with custom thicker gaskets would solve the problem and stop future warping as well.
That massively heavy steel air filter housing is part of the problem too, and although getting away from original , a lightweight alloy housing of some description would be a far better idea, only needing a bolt gently nipped up to hold housing on.
dasrice is offline
post #18 of 19 (permalink) Old 01-11-2015, 10:19 PM
And to any solex carb gurus out there: If the external fuel bowl vent is malfunctioning , ie venting to outside when car is running as opposed to being solenoid shut off , what symptoms does the car have?? I have an issue where the m110 will rev beautifully all the way to redline sitting in garage , yet when i take it for a blast, it hesitates once i put load on, at say above 100-120 kmh. Also at lower speeds up hills under load.
Ignition system checks out, fuel pump too so carb is getting correct fuel pressure etc..Any takers??
cheers
dasrice is offline
post #19 of 19 (permalink) Old 01-13-2015, 02:33 AM
Date registered: Sep 2012
Vehicle: 300sel W109, 280S 70 , 220s 62. 230 66. Lancia Flavia 63.Pininfarina
Quoted: 59 Post(s)
First check .
For a partialy clogged filter !
adler is offline
    4A1 solex carb data teky General Mercedes-Benz 1 11-13-2014 04:36 PM
    TN starter on Solex 4A1 Carb - W123 250 Saloon 1984 iwebst2 W123 E,CE,D,CD,TD,TE Class 3 01-27-2006 09:56 AM
    More Adjusting Solex & Timing. pm220b Vintage Mercedes-Benz 6 07-31-2005 04:50 PM
    Solex to Weber Carb Conversion, where to buy???! baco99 Vintage Mercedes-Benz 15 05-04-2005 12:23 AM
    Solex Carb Repair Kit? baco99 Vintage Mercedes-Benz 3 08-16-2004 09:00 AM
