Air Suspension airbag replacement...HELP! - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 06-06-2007, 07:41 AM Thread Starter
baltobenz's Avatar
Date registered: Jan 2007
Vehicle: 1966 300se coupe
Exclamation Air Suspension airbag replacement...HELP!
I've removed the old air bellows and air can assembly from the front of the car, detached the steel retaining ring and removed the old bellows from the ring. That was the easy part. The problem is getting the new bellows onto the retaining ring. I've tried soaping it up and squeezing it on but it's not happening. It's like trying to install a car tire on a rim without the big air tool they have at tire shops.
I've searched this forum and several others for hours and only came up with how easy a job it is.
baltobenz is offline
post #2 of 4 (permalink) Old 06-06-2007, 08:58 AM
wbain's Avatar
Date registered: Dec 2003
I've never done it. Post your question here:
M-100 Message Board
wbain is offline
post #3 of 4 (permalink) Old 06-06-2007, 07:17 PM Thread Starter
baltobenz's Avatar
I managed pull it on when I got home from work today. Here's how:
Forget about soaping up the bellows, you need to be able to get a good grip on it. Instead, soak it in hot tap water to make it as pliable as the old one you took out. Take it out of the hot water and put the soft part of the bellows through the ring first until one side of the hard rubber ring of the bellows is seated on the metal ring. Then grab the other end of the metal ring with your left hand and pull the rest of the bellows through with your right, using your left thumb to help collapse the bellows and force it though. Pull on it like you're trying to rip the damn thing apart and you will eventually get the whole thing to pop through.
If there's a better way, please let us know. I still have two more to do.
post #4 of 4 (permalink) Old 06-15-2007, 01:05 PM
Date registered: Dec 2006
Vehicle: 30+ mercedes
Rather than soap, use glycerin. It's the stuff mentioned in the service manual.
cth is offline
    Airbag Replacement Bob G W126 S,SE,SEC,SEL,SD,SDL Class 8 11-10-2006 10:51 PM
    airbag replacement my260e W124 E,CE,D,TD Class 3 04-14-2006 09:34 AM
    Airbag suspension on ML's, URL with pics... irondentist W163 M-Class 2 04-28-2004 11:05 AM
    1981 380SEL Air Cell Replacement Hydropneumatic Suspension Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 1 03-09-2002 09:20 PM
    airbag replacement Guest (MBNZ) W124 E,CE,D,TD Class 4 06-15-2001 09:48 AM
