White smoke '73 280SE 4.5 - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 05-29-2007, 03:13 PM Thread Starter
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 99 Post(s)
When starting the old beast from cold, white smoke comes out of the exhaust (no huge nasty plumes, just a good amount). Once the engine is warmed up, the smoke disappears.
When starting the car from warm, no white smoke.
Have I got a problem?
Grubeguy is offline
post #2 of 7 (permalink) Old 05-29-2007, 03:50 PM
Jackasic's Avatar
Date registered: Jul 2005
Vehicle: 72 280SEL 4.5(airbagged), race cars:88 560 SEL, 74 SLC, 67 200, daily: 99 C43, 06 E55 wagon
probably valve stem seals
Performance parts for w126, r/c107, w201, m117, m119, m102, m104 and few other things.
Reproduction 17" Penta wheels coming soon.
Feind Motorsports
Jackasic is offline
post #3 of 7 (permalink) Old 05-29-2007, 06:15 PM
white smoke
white smoke would be condensation,
hold your hand in the plume for moisture test,
blow plume on a paper towel to check for oils/soot.
Check radiator for possible loss.
Blue smoke = oil passing.
Brian O
bostosh is offline
post #4 of 7 (permalink) Old 05-30-2007, 03:53 AM Thread Starter
Grubeguy's Avatar
Quoted: 99 Post(s)
No blue smoke, just white. With worn valve stem seals, can I drive this car about 500 miles without worry?
Grubeguy is offline
post #5 of 7 (permalink) Old 05-30-2007, 09:16 AM
as long as it maintains temperature, oil pressure, and fires on all 8, idles well, drive it. put a quart of cheap ATF in a full tank of fuel.
bostosh is offline
post #6 of 7 (permalink) Old 05-30-2007, 06:11 PM
Jackasic's Avatar
should be fine, it will just leak a little oil in to the cylinders over night. that's what gets burned up on start up.
Feind Motorsports
Jackasic is offline
post #7 of 7 (permalink) Old 05-31-2007, 09:19 AM
baltobenz's Avatar
Date registered: Jan 2007
Vehicle: 1966 300se coupe
What does the ATF do? Is this like using Marvel Mystery Oil?
baltobenz is offline
    White Smoke Explorer945j W202 C-Class 3 03-09-2010 10:47 PM
    White Smoke bloodpirate W124 E,CE,D,TD Class 10 08-04-2009 01:11 AM
    White Smoke SParkyMerc W126 S,SE,SEC,SEL,SD,SDL Class 2 05-12-2006 02:10 AM
    71 280SE - Blowing Black Smoke??? kennodes Vintage Mercedes-Benz 4 04-10-2005 01:22 AM
    White smoke Elgen G-Class 3 12-11-2003 03:57 AM
