» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > General Mercedes-Benz Forums > Vintage Mercedes-Benz
Old 05-10-2007, 02:20 PM   #1 (permalink)
Date registered: Mar 2007
78 240 D vacumm
Does anyone know how much vacumm these cars need to operate correctly?
I installed a vacumm pump kit and I'm getting about 4 - 5 lbs of vacumm and the shut off valve isn't shutting the car off. Thanks! Clark
1978benz is offline   Reply With Quote
Old 05-10-2007, 03:20 PM   #2 (permalink)
E=MB²
GermanStar's Avatar
Vehicle: GermanStar.net
Could be a vacuum leak, could be a bad shut-off valve. They do fail with some regularity. Welcome to BenzWorld, BTW!
German Star
GermanStar is offline   Reply With Quote
Old 05-10-2007, 04:13 PM   #3 (permalink)
Thanks! : )
When I pump my handheld vacuum pump which I attached to the shut off valve, it shuts off right away. I've replaced the lines from the ignition switch valve on the ignition switch and installed a new valve there as well. The rest of my lines hold vacuum just fine when I test them, so I think everything is okay. I'm thinking my rebuilt vacuum pump just isn't generating enough vacuum pressure to operate the fuel shut off correctly. When I drive the car, I'm only accummulating 4 - 5lbs.
Thoughts? Thanks, Clark
vacumm noise yossir29 W126 S,SE,SEC,SEL,SD,SDL Class 5 04-10-2007 12:00 AM
HELP!! need photos or vacumm diagroam for 1992 300SD dieselsteve W140 S-Class 1 11-21-2006 09:05 PM
240 D slowpoke W123 E,CE,D,CD,TD,TE Class 2 11-27-2003 05:59 PM
240 TD beakerboc W123 E,CE,D,CD,TD,TE Class 5 08-13-2003 04:03 PM
My 240 Guest (MBNZ) W123 E,CE,D,CD,TD,TE Class 1 05-07-2002 08:33 AM
