» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > General Mercedes-Benz Forums > Vintage Mercedes-Benz
Old 05-12-2007, 11:30 PM   #11 (permalink)
hbar's Avatar
Date registered: Feb 2007
Vehicle: 1978 Mercedes Benz 450 SEL
Dang, sorry the images are so small. I've not quite gotten the hang of linking to pictures yet.
Working on it..............
hbar is offline   Reply With Quote
Old 05-12-2007, 11:54 PM   #12 (permalink)
hbar's Avatar
This should be a better image of the fuel rails:
http://i209.photobucket.com/albums/b...g?t=1179035500
Old 05-13-2007, 12:00 AM   #13 (permalink)
hbar's Avatar
Bosch CIS K-jetronic upper and lower intake, air meter and fuel distributor and throttle valve body:
http://i209.photobucket.com/albums/b...g?t=1179035760
Old 05-18-2007, 04:19 PM   #14 (permalink)
Boardmonger's Avatar
Date registered: Feb 2005
Vehicle: 83 300d turbo, 79 c123 AMG
Very cool.
For those attempting this, what is the approximate cost of the entire modification? I have K-Jet with aftermarket Lambda on my 79 280ce M110(european import)and it is starting to show its age. I really don't want to start dumping hundreds of dollars on OE parts and still have fuel issues. I am also very interested in hearing about performance/mileage improvements.
-Zack K.
1983 300d Turbo (Daily Driver) -- 243,000 miles
1979 280ce AMG (Sadly sitting, awaiting justice) -- 141,410 miles
1981 300d Euro 4 speed -- 188,421 km -- Sold
1979 300d Euro 4 speed -- 265,000 miles -- Brother's
1995 E300 Diesel -- 49,000 miles -- Dad's
1977 300d -- 148,000 miles -- everyones
A Collection of w123 AMG Cars and Parts
Boardmonger is offline   Reply With Quote
Old 05-21-2007, 11:08 AM   #15 (permalink)
hbar's Avatar
The cost of the Megasquirt unit itself is minimal, about $400 prebuilt and tested for you but the "miscellaneous" parts such as sensors, fuel injectors, wiring etc.. can be cheap if you already have them or can get them used, to many hundreds of dollars more if you need to purchase them.
I've got about $1000 invested already and will probably spend a few hundred dollars more by the time it's done, but I'm doing the "full" conversion to a crank sensor Distributorless Ignition system.
A frugal person could probably do the entire fuel only conversion for less than $500 finished.
More info:
MegaSquirt EFI :: Index
Old 05-21-2007, 06:37 PM   #16 (permalink)
Date registered: Mar 2007
Vehicle: 1980 450slc
My father has been ill and I went to visit him this weekend so I have made no progress on my install but I have started to put together a website. Here is a link to my INCOMPLETE bill of materials to help you with some idea on cost.
[url=http://www.hitechengineering.net/DNN/MegaSquirted450slc/tabid/54/Default.aspx[/url]
I will continue to update my website as time permits.
oughtsix is offline   Reply With Quote
Old 05-21-2007, 11:21 PM   #17 (permalink)
I changed all of my photos from jpg's to giff's to save room on my server and to save bandwidth. All of the photos are available on my website here:
450slc megasquirted
Old 05-28-2007, 06:25 PM   #18 (permalink)
I was able to spend some time on my install this weekend. I got everything back together and wired everything with the relay board. I pulled out a lot of stock ignition wiring and cleaned things up. I spent a good hour trying to get her started back up and it would run for 15 seconds then die. This frustraited me for a while then I remembered having the same problem when I initially got her running.
TIP: If you are using the stock fuel relay it will not energize unless the system detects the engine is running. I.e. No Tach = No fuel = No go!
When you turn the ignition key the fuel relay energizes the fuel pump for a moment then turns off power to the pump. When the fuel relay circuit detects the engine is running it energizes the fuel pump again. The green/yellow wire from the bosch ignition box needs to be connected the the green wire and green/yellow wire from the diagnostic connector.
Old 05-28-2007, 06:29 PM   #19 (permalink)
Date registered: Dec 2003
Vehicle: 1989 420SEL, 1965 220S, 2002 Ford Crown Vic Police Interceptor
Why don't you use the Megasquirt fuel pump relay control?
Near Manassas Va. '65 220S2002 Ford Crown Victoria Police Interceptor, 89 420SEL
Had '65 220SE, 67 230S, 72 280SE 4.5 Dad had '65 300SE LWB, '65 220SE, '89 300SE
"Of all tyrannies, a tyranny sincerely exercised for the good of its victims may be the most oppressive." C.S. Lewis
wbain is online now   Reply With Quote
Old 05-29-2007, 11:10 AM   #20 (permalink)
The stock fuel pump relay circuit works very well and everything is already wired in with the proper fuses etc. The only thing you have to make sure of is that you feed a tach signal to one wire in the engine bay. This can be a tach signal from the stock Bosch ignition, the Ignition out line from Megasquirt or the tach out from the MSD. Either way it saved a lot of wiring using the stock fuel relay and has proven to be reliable. I just needed to refresh my memory from over a year ago about the tach signal. The Tach signal also feeds the instrument cluster tachometer.
I pulled the majority of the stock ignition wiring to straighten things up. I am running a MSD6AL for ignition. This made the stock ceramic low resistance resistors mounted on the driverside fender surperflous. The MSD drives the coil directly and does not need any external resistance. Under the mounting point for the resistors on the driver side fender there is a 2 post terminal strip. On one of the posts is a green/yellow wire and a green wire. I believe the green/yellow is the tach signal for the dash tachometer. I believe the green wire is the tach signal for the fuel relay circuit. I believe the green/yellow wire from the Bosch ignition box was originally connected here. I just needed to reconnect it after my cleanup.
The fuel relay circuit is completely independent of the K-Jetronic CPU. I have my K-Jetronic module completely removed and the fuel relay circuit still functions as it should. My theory is that the tach signal detection is actually within the fuel pump relay itself but it has been quite a while since I looked at this schematic.
I am considering removing the bosch ignition box altogether to further simplify things. This would leave megasquirt reading the tach signal directly from the distributor (VR I believe). But for right now the Bosch box is doing a good job of conditioning the signal and with the MSD driving the coil (or megasquirt directly) there is really no load on the bosch box. By my thinking this means it should last a long time as the power transistors are switching a very small fraction of the current they were designed for.
Any way it is nice to have the old girl back on the road again! I drove her to work for the first time in about two years. She was running over a year ago and running well a few months ago but the rats nest wiring was pretty bad. Installing the MegaSquirt relay board made a huge difference in the cleanliness of the install. I also feel much much better about the reliability as everything is well laid out and tight.
I hope to post some pictures and commentary about the wiring on my website later on this week. I will also post some gas mileage figures as they start adding up here in this forum.
Bosch D Jetronic and K Jetronic Troubleshooting Nutz 4 Benz W116 S, SE, SEL, SD Class 41 10-31-2009 09:05 PM
Fs: 190e 16v Megasquirt Efi Hardware Kit (fuel Rail, Regulator, Throttle Body, Etc) kiato4 W201 190 Class 2 03-22-2007 10:36 PM
Fs: 190e 16v Megasquirt Efi Hardware Kit (fuel Rail, Regulator, Throttle Body, Etc) kiato4 For Sale, Trade & Wanted Items 0 03-21-2007 09:49 PM
Fs: Complete Megasquirt Efi Kit For Mercedes 190e 16v!! kiato4 For Sale, Trade & Wanted Items 1 01-25-2007 09:31 PM
FS: Complete EFI Megasquirt Kit for 16v!! kiato4 W201 190 Class 1 01-25-2007 09:30 PM
