Replacing Bosch jetronic with MegaSquirt EFI - Page 12 - Mercedes-Benz Forum
post #111 of 124 (permalink) Old 10-10-2010, 02:26 PM
Date registered: Jul 2004
Vehicle: 1971 280SE 3.5 Coupe
Quoted: 8 Post(s)
I am beginning work on my Megasquirt conversion. I had a custom crankshaft trigger wheel fabricated for EDIS, had a distributor hole plug machined, using a Saab throttle position sensor, using Ford 19lbs injectors-they fit perfectly if D-Jetronic pintle caps are used-and a custom O-ring fuel rail to get rid of the hose clamps and short hoses on the injectors. The original D-jetronic injectors are hughly to large and will result in very short pulses-they are over 50lbs. That's probably why D-jetronic cars always seen to run rich. I am researching using Coil-on-plug with the EDIS.
Tony
280SE 3.5 Coupe
Stick shift
3.27 Axle
5.6 Iron block build in progress
3.5 Tony is offline
post #112 of 124 (permalink) Old 10-12-2010, 08:09 PM
Jackasic's Avatar
Date registered: Jul 2005
Vehicle: 72 280SEL 4.5(airbagged), race cars:88 560 SEL, 74 SLC, 67 200, daily: 99 C43, 06 E55 wagon
What aftermarket fuel rail are you guys running? Where are you buying your MS boxes from?
Performance parts for w126, r/c107, w201, m117, m119, m102, m104 and few other things.
Reproduction 17" Penta wheels coming soon.
Feind Motorsports
Jackasic is offline
post #113 of 124 (permalink) Old 10-12-2010, 08:15 PM
wbain's Avatar
Date registered: Dec 2003
I bought my MS V3 from DIYAutoTune.com Megasquirt Kits / Assembled Engine Management Systems, Wideband o2 Sensor Systems and tuning products. The service was great and the site is complete.
I just bought a 280SE 4.5 D-Jet fuel rail and injectors from a wrecking yard. They will fit my 420SEL well.
wbain is offline
post #114 of 124 (permalink) Old 01-27-2012, 09:55 AM
Date registered: Mar 2011
Vehicle: 1972 280 SEL 3.5 - RHD
curious as to how you got on mate,
im just thinking of doing the same thing to a 3.5 just getting started on the electronic ignition setup at the moment.
brendannw is offline
post #115 of 124 (permalink) Old 04-12-2012, 09:01 AM
Date registered: Sep 2008
Vehicle: 1975 450SL
Quoted: 15 Post(s)
Megasquirt of a '75 450SL. MS1 v3 board
Getting into this project now. I've got the board pretty much built, and most all of the sensors accumulated. Plundered a Saab 9000 at a junkyard for ICV and TPS. I'm trying to hook up with a welder to fabricate a plate to put a wideband O2 sensor in place of a EGR valve on the manifold ('75 is the first year of the cat + exhaust manifold).
I originally planned to go fuel only, but it looks like the spark control would be not too much more to do. I need some input on how / where to get a crank sensor wheel attached. The harmonic balancer has 2 notches that need to be kept clear for access to two water pump bolts, so that is a complication. Does anyone have any suggestions or advice?
Thanks,
Scott
RadioTek is offline
post #116 of 124 (permalink) Old 04-12-2012, 02:30 PM
Date registered: Apr 2009
Vehicle: Mercedes 280 SE 3.5 coupe, pagoda 230 SL '64, 500 E W124, CE 220 Cabrio, E 320 T W211, w126 6.0 AMG
Trigger
If you have automatic transmission I would go at the bag of the engine. The automatic tranny has a starterwheel which is in between two distance plate of 3 mm, so you can use in the front a Triggerwheel instead of the spacer and the sensor goes dow near the oil pan. Look on 108---113 mods.
Best Pagodino
pagodino is offline
post #117 of 124 (permalink) Old 04-13-2012, 06:37 PM
Vehicle: 1975 450SL
Quoted: 15 Post(s)
Best Pagodino
That sounds interesting. I do have the automatic. Does the transmission have to be pulled to do that? Do you have a link to any pictures or descriptions?
I seem to remember that some other makes have the Crank Position Sensor on the starter flex plate.
My problem is that I have to do this as economically as possible.
Scott
RadioTek is offline
post #118 of 124 (permalink) Old 10-06-2012, 04:01 PM
V12StealthHunter's Avatar
Date registered: Jul 2007
Vehicle: w201,w124,w126
Quoted: 21 Post(s)
Interested in seeing the above mod as well.
V12StealthHunter is offline
post #119 of 124 (permalink) Old 02-19-2014, 02:08 AM
MCMLXIX's Avatar
Date registered: Dec 2013
Vehicle: 2006 S65 AMG V12 Biturbo
Quoted: 87 Post(s)
back from the dead for updates... lets see some pictures on how things turned out...
Rich
2006 S65 AMG 1 of 427 in North America {For Sale}
1986 560SEL {FOR SALE}
MCMLXIX is offline
post #120 of 124 (permalink) Old 02-20-2014, 04:56 PM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
are you talking about the 2 position switch [ idle / full load ] that is at the butterfly ??? , if so there is another easy fix to no idle contact . let me know , if so will tell you on how to do it for next to nothing .
aluminum likes this.
agillot is offline
    Bosch D Jetronic and K Jetronic Troubleshooting Nutz 4 Benz W116 S, SE, SEL, SD Class 102 01-07-2016 09:22 PM
    Fs: 190e 16v Megasquirt Efi Hardware Kit (fuel Rail, Regulator, Throttle Body, Etc) kiato4 W201 190-Class 8 02-23-2011 11:39 AM
    Fs: 190e 16v Megasquirt Efi Hardware Kit (fuel Rail, Regulator, Throttle Body, Etc) kiato4 For Sale/Wanted/Trade/Giveaway 0 03-21-2007 08:49 PM
    Fs: Complete Megasquirt Efi Kit For Mercedes 190e 16v!! kiato4 For Sale/Wanted/Trade/Giveaway 1 01-25-2007 08:31 PM
    FS: Complete EFI Megasquirt Kit for 16v!! kiato4 W201 190-Class 1 01-25-2007 08:30 PM
