Go Back   Benzworld.org - Mercedes Benz Discussion Forum > General Mercedes-Benz Forums > Vintage Mercedes-Benz
Old 04-23-2007, 11:41 AM   #1 (permalink)
Date registered: Mar 2007
i.p. diaphram
where is a good place to buy a new diaphram for the i.p. on a 74 240-d. i have looked around and they run a little over 200 bucks but i thought i read a post on here where someone had gotten one for 58 dollers. thanks for the help.
smokydog is offline   Reply With Quote
Old 04-30-2007, 11:55 AM   #2 (permalink)
KCM
Date registered: Jun 2004
If you are talking about the diaphragm for the vacuum governor on the back of the injection pump, the dealer had them for around $75 a couple years ago. Had also checked with and aftermarket parts suppliers and they were not much cheaper than the dealer.
KCM is offline   Reply With Quote
Old 05-02-2007, 09:19 AM   #3 (permalink)
thanks for the reply, the closest dealer to me is 250 miles away and diden,t know much about this model car but did reffer me to one a little further away. i will give them a try.
Old 05-02-2007, 10:13 PM   #4 (permalink)
KCM
Did some checking. The part number for the injection pump diaphragm for a 1974 240D, body 115.117, engine 616.916, is 000 075 06 07. This diaphragm is located a the top rear of the injection pump. There is also a gasket, part number 001 074 23 80. Checked my records, and the price was $75.60 from the dealer, but that was back in 2002 (can't believe it was that long ago). Hope this helps.
Old 05-03-2007, 05:56 AM   #5 (permalink)
many thanks, will call the dealer with these numbers and see if i can't get one comming. thanks again for the help.
Replace vacuum pump diaphram or not joeschmoe W123 E,CE,D,CD,TD,TE Class 2 06-25-2006 08:59 AM
