1971 250c creaking noise - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 04-14-2007, 12:24 PM Thread Starter
Date registered: Oct 2006
Vehicle: 1983 300cd
Well,
It's running great and a ton of fun to drive. New problem however,
When you turn the steering wheel it makes an awful creaking noise.
I have replaced the subframe mounts and the tortion bar bushings.
I have greased the joints and I still have the problem.
Has anyone had this problem and would you please share any possible solutions.
virginia car guy is offline
post #2 of 7 (permalink) Old 04-14-2007, 12:35 PM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 99 Post(s)
Steering box maybe?
Grubeguy is offline
post #3 of 7 (permalink) Old 04-14-2007, 12:41 PM Thread Starter
Vehicle: 1983 300cd
The steering is very tight with no play. If I can't figure something else out that will be the next step.
Thanks
post #4 of 7 (permalink) Old 04-14-2007, 04:51 PM
Date registered: Jun 2004
Quoted: 5 Post(s)
It can only be a seized tie rod or drag link end ,a seized idler bush on the passenger side or ...'The dreaded Steering box fitting in the chassis cracks'.
Look at the three bolts that hold the box to the chassis rail,clean it with a wire brush and examine very closely for cracks around the three bolt heads.
It's easily fixed with steel plate to reinforce the chassis but it's a common problem.
mercmad6.3 is offline
post #5 of 7 (permalink) Old 04-15-2007, 06:46 PM Thread Starter
Vehicle: 1983 300cd
Thank you very much for the information.
I will check those items tomorrow.
post #6 of 7 (permalink) Old 04-17-2007, 05:48 AM
WarrenM's Avatar
Date registered: Feb 2004
Vehicle: 1972 280E/8
Broken engine Mounts-they may look ok but engine can "lean" and hit chassis rail or steering box.
Cracked chassis in vicinity of steering box/engine mounts.
As merc.mad6.3 said common fault but easily fixed.
Warren
Western Australia
WarrenM is offline
post #7 of 7 (permalink) Old 04-25-2007, 08:17 PM Thread Starter
Vehicle: 1983 300cd
Thanks everyone for your advise. Replaced upper & Lover control arm bushings, idler arm bushing and engine mounts. Not only has the noise dissapeared but I think that I have the nicest riding 250c on the planet. Thanks again!!
    Newbie Alert - 1971 250C Break Question LeggoMyEggo Vintage Mercedes-Benz 2 02-11-2007 05:37 PM
    1971 - 250C - Warning NEWBIE QUESTION LeggoMyEggo Vintage Mercedes-Benz 1 01-17-2007 08:37 PM
    Creaking Noise... Not shocks Bklyn1971 W163 M-Class 5 04-25-2005 07:36 PM
    1971 250C aucaster Vintage Mercedes-Benz 0 01-20-2005 02:28 PM
    Creaking noise Joe R170 SLK-Class 4 01-08-2002 09:21 PM
