114 4-spd auto flares in 2nd. - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 04-09-2007, 11:51 AM Thread Starter
Date registered: Apr 2007
Unsure what the actual trans number is. The problem is that when going from 4th to 2nd (ex: decellerating and coming to a stop) the transmission goes into a sort of neutral but also vibrates in a rythmic manner. As soon as the operator taps the gas the transmissin re-engages with a thud. I said it goes into neutral but it isn't neutral because if I shift into neutral while the problem is occouring the vibration stops. I've tried adjusting the kickdown rod but it has little effect on the problem. As I understand it there is a band, B1 I think, that is related only to 2nd gear. However, I'm thinking it may be a problem in the valve body as the problem only happens after shifting from a higher gear. Another interesting observation is that if I drive with two feet and keep the accelerator pedal depressed at a stop, the problem only occours breifly and quickly clunks back into gear. Keep in mind in this insatnce I am not increasing engine speed, just taking the play out of the throttle linkage. Since there was no actual engine speed increase I don't think it is a pressure problem. I have replaced the fluid and the problem did not change.
Anyone experienced this before, have a quick fix? This car has been in storage for 15 years.
Thanks in advance for any words of wisdom.
JoeZeeuw is offline
post #2 of 3 (permalink) Old 04-10-2007, 06:30 AM Thread Starter
where's the gurus?
JoeZeeuw is offline
post #3 of 3 (permalink) Old 04-10-2007, 04:52 PM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 95 Post(s)
15 year storage? Sounds like a tranny going bad. Take it to Aamco for a checkup or something. They don't cost much (checkups).
Grubeguy is offline
    W124 auto normally start from 2nd gear? ooifa W124 E,CE,D,TD Class 13 09-09-2006 03:45 AM
    Auto takes off in 2nd. red_benz W201 190-Class 4 10-19-2005 11:37 PM
    5 spd auto in limp mode .. should it light the CEL? AlanMcR W140 S-Class 1 07-23-2004 03:15 PM
    Auto 5 spd or Auto 4 spd? I-6 or V -8? Flatbar G-Class 2 07-03-2003 08:18 PM
    190E-2.6 auto tranny starts in 2nd Guest (MBNZ) W201 190-Class 3 02-20-2002 08:10 PM
