Turbo 220D??? Can you do it? - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 04-08-2007, 01:33 PM Thread Starter
Date registered: Sep 2006
Vehicle: 1971 Mercedes 220D 8k original Miles!
I wanted to see if anybody has heard of putting a turbo on a 220D Motor?
If so what work needs to be done? Can you take a turbo kit from a 240 Turbo and put it on directly?
GermanlookT3(Tom) is offline
post #2 of 2 (permalink) Old 08-26-2010, 02:39 AM
Date registered: Aug 2010
Anything can be made to fit with some cutting, welding, and/or fabricating. Keep the turbo small for that car, and waste gate design best for it. Look at some of the threads here there was one I saw with some pics and he did a pretty good job getting it done. You only need enough for 7-10 psi boost so keep it small these aren't stock made turbo so be careful. Check out www.turbobygarrett.com for some info. I don't know if any have done on a 220D on this forum but I'm in the process of rebuilding my motor for my 72' 220D and I will be fabricating the turbo system myself. It's easier if you are a mechanic like myself or have a buddy who owns a shop to get work done. It could be costly for custom fabrication if you just go to a shop walk-in. Bottom line, yes it can be done but I'm not sure if just a swap would work without some work.
dre1976 is offline
    Turbos on the non turbo engines 220D 240D 300D....people have done it! DieselKraut W123 E,CE,D,CD,TD,TE Class 23 02-13-2006 02:07 AM
    220D Help screwjackfoo Vintage Mercedes-Benz 2 11-16-2005 04:02 PM
    220D gremlins txiripoi Vintage Mercedes-Benz 2 10-03-2005 09:15 AM
    '71 220D gearing BluEyes Vintage Mercedes-Benz 1 01-02-2005 02:56 PM
    220d chow Vintage Mercedes-Benz 0 06-20-2004 08:13 AM
