alignment question - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 04-08-2007, 10:39 AM Thread Starter
carybrief's Avatar
Date registered: Mar 2007
Vehicle: 1985 mercedes 300sd
alignment question
85 300sd just had a bunch of front end work and an alignment but I still have some pulling to the right. b4 I go back whining - do these old cars ever align good - I have heard they dont but that was probably because the guys car needed an alignment or front end work.
. If they do align well I'll bring it back to the shop thanks alot..
carybrief is offline
post #2 of 4 (permalink) Old 04-09-2007, 05:56 AM
Date registered: Jan 2004
Quoted: 30 Post(s)
Yes, the do align perfectly if all the front end parts are good. They do not align perfectly if you use a shop that does not use the spreader bar or the tool to lock the steering box in place. If they don't use them or say that their equipment is good enough to not need them, then go somewhere else.
Len
sokoloff is offline
post #3 of 4 (permalink) Old 04-09-2007, 10:13 AM
Date registered: Jun 2006
Vehicle: 1981 300CD, 1973 280C
In rare cases a tire can get a "set" to it that will cause a radial tire pull. Try swapping the right rear tire for right front. If a vehicle is driven misaligned, the tire wear now present will cause a pull even if the car is now aligned.
carnut1 is offline
post #4 of 4 (permalink) Old 04-09-2007, 11:46 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 102 Post(s)
Is it possible you have a sticking brake rotor?
Grubeguy is offline
    alignment question boomie W163 M-Class 17 12-27-2005 11:24 PM
    Alignment question. CERY C208/A208 CLK-Class 1 10-27-2004 04:30 PM
    Alignment question? Enforcer W203 C-Class 3 06-24-2004 02:07 PM
    Basic question on alignment caseydellas W126 S,SE,SEC,SEL,SD,SDL Class 3 01-17-2004 02:55 AM
    Need HELP with alignment parameters question: getting alignment redone tomorrow. Dan - SF Bay Area R170 SLK-Class 13 01-10-2002 10:34 AM
