'70 250C Lost! cant find my oil pressure! - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 04-07-2007, 01:40 PM Thread Starter
joshdvirnak's Avatar
Date registered: May 2005
Vehicle: 1970 250C
Hey, hoping you all can help me out here. last summer i was driving my 250C when I lost oil pressure, I shut it down right away and towed it to my dads shop. My dad does mechanic work so he will be a big help, I was wondering where I should start, I havent torn into it yet but obviously I should probably start at the oil pump.
How would you guys go about tackling this problem? I got a haynes manual for it, but there is nothing better than personal experiance and if anyone on here has done anything like this in the past, I would appreciate some pointers.
btw, I had asked a question about this last fall, but never had time to get to working on it, but I need to get it going this spring, the fiance wants to ride off in it on the wedding day
Thanks, Josh
Edit, there were a couple posts on my original thread that I never saw, and autozen said that the fuel pump is driven off of the oil pump, the car was still running when I shut it down (obviously) so, if the oil pump is still working what else could it be? and if the oil pump did quit, killing the fuel pump, how long would it stay running? a few seconds? a minute? maybe i saw it right after it gave out... just some thoughts. thanks!
joshdvirnak is offline
post #2 of 3 (permalink) Old 04-08-2007, 01:52 AM
Date registered: Nov 2006
Vehicle: 78 450 SL; '68 Ford Bronco
If the oil pressure gauge suddenly started reading zero I'd suspect the oil preassure sending unit was faulty. I'm not too familiar with your motor, but most cars have the sender right next to the oil filter. You should measure resistance between the 'lectric connector and a good ground. Also measure the voltage at the connector with the ignition switch in the RUN postion. Maybe someone else here could post what the measurments are supposed to be.
If the oil pressure slowly went down as the motor heated up to normal temperature your probably looking at replacing the main bearings (at the least). A complete rebuild may be needed.
A worn out oil pump is a possibility, but that is usually not the case.
--Reiteration; this is typical of most ordinary cars. I'm not too familiar with your particular motor. In fact, I don't know if the gauge is even electrically or mechanicaly operated. If it's a mechanical gauge, I would say a leaky connecting line is the prime suspect.
Chris from Whidbey Island
I've got a lovely bunch of coconuts.
U14NLD is offline
post #3 of 3 (permalink) Old 04-08-2007, 05:17 AM Thread Starter
Vehicle: 1970 250C
I believe that it is a mechanical guage, and while I have looked and havent found any leaks or drips, that doesnt mean that a line couldnt be plugged somewhere, right? Also, I am currently on the other side of the state right now, the car is still at my dads shop, so dont have eyes on it now, I am just trying to get a starting point and an idea of where to start.
    Oil pressure gauge showing no pressure justin2 W140 S-Class 1 11-06-2006 09:38 PM
    1970 250C Oil Pump Problems joshdvirnak Vintage Mercedes-Benz 7 09-27-2006 08:28 AM
    Oil Pressure drop after oil change???? threepoint1415926 W124 E,CE,D,TD Class 22 05-12-2004 09:05 AM
    HELP!!! I lost my service manual and I need a diagram so I can finish my oil change!! Geeky1 W126 S,SE,SEC,SEL,SD,SDL Class 5 03-28-2004 07:20 PM
    oil pressure and oil temp sender NickT G-Class 6 09-03-2002 09:42 AM
