300se coupe interior light issue - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 04-06-2007, 06:34 PM Thread Starter
baltobenz's Avatar
Date registered: Jan 2007
Vehicle: 1966 300se coupe
Minor problem but I can't seem to track it down. The interior light doesn't come on when I open the driver's door but works with the passenger door. I checked the door switch and didn't find fault with it. I understand that the driver's door is on a time delay where the light stays on for a few seconds after the door is shut.
Is there a relay switch somewhere that I need to check?
Thanks,
Tom
baltobenz is offline
post #2 of 2 (permalink) Old 04-15-2007, 06:11 PM
Date registered: Feb 2007
Vehicle: '70 111 280SE 3.5 coupe (4 speed manual stickshift)
When you say you "checked the door switch" what do you mean? I had the same problem and when I took the leather panel off, I saw that the plug to the switch was disconnected on my coupe. Check whether you have any power on your electrical supply wire. Also, double check whether your switch really closes the circuit. If that is all OK, it must be in the circuit leading from the siwtch to the light.
Good luck.
sjefke is offline
    1992 300se dashboard issue david patterson W140 S-Class 5 01-29-2007 10:19 AM
    1990 300SE Radio Wiring Issue W126 thazsar Audio & Telematics Forum 1 01-02-2007 07:25 PM
    1990 300SE Radio Wiring Issue W126 thazsar General Mercedes-Benz 2 01-02-2007 07:24 PM
    Brake-light issue leading to BAS/ESP issue??? Isoplus R170 SLK-Class 7 06-17-2006 12:57 PM
    OT: If you think brake light or peeling interior is an issue - Check what's Ford up to Kirill R170 SLK-Class 3 04-18-2006 08:13 PM
