Help? Window problem 73 450 SL - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 03-30-2007, 05:37 PM Thread Starter
DeidreB's Avatar
Date registered: Jun 2004
Vehicle: 1973 450SL, 1984 300sd
Thumbs down Help? Window problem 73 450 SL
I have a 1973 450 SL. My passenger door window slid down and then clunked to the bottom of the door and I can no longer make the window go up.
Here is the info I have:
The window relay switch is newish (replaced last summer).
I have opened the door by taking the panel off.
The window is properly seated in the scissor mechanism (sorry I don't know the part name!), which seems to work fine, and the motor works fine. The scissor arm that is near the "D" shaped gear is not attached to the "D" gear; there is a white plastic rectangle with a round hole the size of a dime that appears to slide back and forth on this arm. When I press the window control button the "D"gear rotates but does not push up on the arm. If a helper manually pulls and holds the window up, pressing "down" on the control will pull the window down, but the nchaism does not push the window up on it's own. The arm with the plastic rectangle is behind the "D" gear when viewed from inside the car. Does anyone have a photo or diagram of how these two parts are supposed to go together? Autohaus Arizona sells the window regulator assembly and it includes the scissor mechanism with the "D" gear, would it be wise to simply replace the entire assembly?
Spring hit this week in Ottawa and it is making me slightly insane to not be driving the car. Any help would be most welcome!!!
best wishes,
DeidreB is offline
    Problem with my window DO_Doc R170 SLK-Class 2 12-10-2006 10:14 AM
    Window Problem QuangsBenz W124 E,CE,D,TD Class 1 04-15-2006 05:14 AM
    1976 450 SLC stalling problem in Vancouver Canada, Gordon Foster Gordon Foster R/C107 SL/SLC Class 0 09-29-2003 08:37 PM
    Window and A/C problem Guest (MBNZ) W123 E,CE,D,CD,TD,TE Class 3 07-18-2002 05:45 PM
    Additional Information on problem 450 SL- Help! Guest (MBNZ) General Mercedes-Benz 2 03-31-2002 11:28 AM
