W111 Coupe Engine Bay Bulkhead Material - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 03-21-2007, 04:40 AM Thread Starter
alydon's Avatar
Date registered: Mar 2004
Vehicle: 84 500SEL AMG, 90 560SEC AMG, 85 500SEC AMG Widebody
Quoted: 36 Post(s)
I am restoring the engine bay of my 61 220SEb W111 coupe. The material on the bulkhead is missing in some areas. Where can I locate close to correct material? Does this material have a quilted pattern or other texture? Is it a foam backed vinyl?
Thanks in advance.
Al Lydon
alydon is offline
post #2 of 4 (permalink) Old 03-22-2007, 12:06 AM
wbain's Avatar
Date registered: Dec 2003
Mine looks like horsehair. The covering is not quilted. The quilted variety is a reproduction. 230/250/280 SL's have a similar material.
wbain is offline
post #3 of 4 (permalink) Old 03-24-2007, 07:31 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 95 Post(s)
I bought some mylar-coated foam padding for my 280. It's advertsied as temp resistant, etc, so I'm wondering if one could use something like that for the engine bay. Check out JC Whitney - the catalogs they publish have all kinds of stuff in there for high temp applications. You'd need to cut the pieces to size, and the car wouldn't be "original" ...
Grubeguy is offline
post #4 of 4 (permalink) Old 03-27-2007, 04:44 AM
Date registered: Jun 2004
Quoted: 5 Post(s)
It's a jute material with a black synthetic covering on the engine side.It's normqlly glued into place with regualr contact adhesive.It's normally very long lasting so if you want to have the corect factory look start checking out wrecks and recycle the best ones you can find.I scrape them off with a broad putty knife after I remove all throttle links,regualtors etc etc .
I am sure it's no longer available from the classic center,W109 stuff isn't as I have already tried to find it.
mercmad6.3 is offline
    Material for 95 C280 engine wiring harness macywong W202 C-Class 3 02-01-2007 07:49 PM
    MY2004/2005 bulkhead TSB Wolfgang W163 M-Class 0 12-18-2005 07:26 PM
    Rust on bulkhead concorde R/C107 SL/SLC Class 2 06-30-2004 10:13 PM
    Help! My SLK engine mods cause excessive engine bay heat DougE R170 SLK-Class 9 11-23-2002 02:31 PM
    Do you guys pressure spray your engine bay? How do you all clean your engine bays? Arnee R170 SLK-Class 6 02-15-2001 04:33 PM
