Just bought a 66' 300se coupe - Page 2 - Mercedes-Benz Forum
post #11 of 20 (permalink) Old 03-08-2007, 08:55 PM
wbain's Avatar
Date registered: Dec 2003
Wow, nice car. All of the D.C. and Balto. area owners should have a GTG when the weather warms up.
Your engine mounts have collapsed. Check the space between the oil pan and the subframe. On the other hand the exhaust pipe sealing rings may be missing.
Also, get a grease gun and some good grease, like Mobil 1 synthetic, and grease all your suspension grease points. Every joint on the front suspension has one, there are two or three on the drive shaft and 4 on the rear axle. Two are on the swing axle joint and two are on the brake torque compensation bearings at the calipers. These are often forgotten and deteriorate.
If you cannot grease any, they must be cleaned out.
Check this Russian web site, On panel 2, the bearing is part 181, the zerk fitting is part 197.
Russian Web Site Info etc...
It've found the site to be a good resourse but I've found that the part numbers are different from the dealer. YMMV
Models W112, and W109 are very similar mechanically.
Also, check these guys for air suspension info:
Star Motors - Home
and the M100 group. the 6.3's etc have the same air suspension.
http://www.m-100.net/iamo/Controller?ac=Home
You're very lucky that the injection pump was replaced. The distributor has dual points.
wbain is offline
post #12 of 20 (permalink) Old 03-08-2007, 11:56 PM
Always Remembered RIP
cascade's Avatar
Date registered: Nov 2006
Vehicle: 1991 560SEC AMG
Location: Grass Valley, N. Calif. / Gardnerville, Nevada
Quoted: 17 Post(s)
Send a message via AIM to cascade
Gorgeous car, a timeless design. To this day, they are highly cherished in the fatherland.
Jim
<--- superschnelle 300 hp 10:1 ECE euro HV, Hochverdichtung = high compression (11/2011) ... Wie im Freien Fall. Nur horizontal.
"I swear to god, it's like I live in a trailer of common sense, and stare out the window at a tornado of stupidity." >'='<
cascade is offline
post #13 of 20 (permalink) Old 03-20-2007, 04:05 PM
Buzz's Avatar
Date registered: Feb 2004
Vehicle: CL55
Epa/dot?
Beauty!
I see there are no side markers on the car. Are there any EPA/DOT federalization issues with this car? Is it old enough that there is no such requirement? I ask because I am looking at a 66 300SE cab...
Buzz is offline
post #14 of 20 (permalink) Old 03-20-2007, 08:32 PM
wbain's Avatar
Originally Posted by Buzz
Beauty!
All that started in 1968 as I recall. The car could also be a late 65. The chassis number would help.
wbain is offline
post #15 of 20 (permalink) Old 03-21-2007, 04:12 AM
Buzz's Avatar
Vehicle: CL55
The VIN is 112.023-10-009.34
Buzz is offline
post #16 of 20 (permalink) Old 03-22-2007, 12:10 AM
wbain's Avatar
The digits after the 10, which would be the sequence number, are incorrect. There should be 6 numbers.
Here is an interesting website:
300SE_Main_Page_1
wbain is offline
post #17 of 20 (permalink) Old 03-26-2007, 11:32 AM Thread Starter
baltobenz's Avatar
Date registered: Jan 2007
Vehicle: 1966 300se coupe
Beauty!
In Maryland, when a car is registered "historic" there is no inspection, so there are no such issues. My experience in NY was that if the car wasn't built with it, (marker lights, seat belts, etc...) it's not required. However, I haven't registered a car in NY for 12 years so things may have changed.
BTW, my VIN # is 11202112008658
The option codes from the tag on the right side of the radiator support are:
493 508
040 G
112 021 12 7
3 00145 0025
I found out that 493 is a heavy duty heat exchanger, 040 is black exterior, and 12 is a lefthand drive automatic. The rest, other than 112 021, is a mystery. Can anyone help with the other numbers?
baltobenz is offline
post #18 of 20 (permalink) Old 03-27-2007, 06:14 AM
Date registered: Oct 2006
Vehicle: 1967 250SE (German market coupe, 4sp sunroof), 2000 Europa G500 (early model)
Correct. From a Federal point of view, "anything goes" for cars built prior to Jan 1, 1968. From my limited knowledge of NY rules, the same is true.
From a Maryland point of view, you'd be exempt from emissions anyway, but still have to go through the indepth safety inspection.
In many states, registering as an Historic vehicle exempts you from any inspection, provides as less expensive registration, and carries very few restrictions (you're not supposed to use the vehicle for routine transportation, like to work). However, I don't know the details of what NY does here...
Nice car!
Bill
(Frederick, MD)
wcelliot is offline
post #19 of 20 (permalink) Old 03-31-2007, 11:04 AM
Vehicle: 97 E420, 82 300CD, 76 240D
wow beautiful car i thought i have seen them all, i new about the convertable but a hardtop coupe, u should find out exactly how many were made. u got a great deal on it too, i am so jealous
ismiley is offline
post #20 of 20 (permalink) Old 03-31-2007, 10:31 PM
benzmizer's Avatar
Vehicle: 1983 240d AT; 1993 e320 AT
Quoted: 4 Post(s)
Nice catch! Congratulations!
benzmizer is offline
    Help with a 66' 250s brent245 Vintage Mercedes-Benz 2 09-24-2006 03:58 PM
    Just got a 64 300SE Coupe markus765 Vintage Mercedes-Benz 24 01-10-2006 09:52 PM
    New 126 owner. Just bought a 300SE :D 1985 300CD W126 S,SE,SEC,SEL,SD,SDL Class 26 05-23-2005 08:18 PM
    Just bought a 300se, and I want euro headlights Prissy6990 W126 S,SE,SEC,SEL,SD,SDL Class 4 12-05-2004 06:53 AM
    300SE coupe mercnmini Vintage Mercedes-Benz 3 07-16-2004 08:07 AM
