'77 300D Oil Pours Out of Air Filter - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 03-04-2007, 02:01 PM Thread Starter
Date registered: Mar 2007
My niece purchased a '77 300D and while it was always hard to start - it has now developed a nasty habit of having oil pour out of the air filter when it is running. I have already convinced myself that it needs a ring/head job but could there be another cause? Also, how long should I plan for the rering work? I have rering'ed 3 other cars but have never had to pull one out of the car....
Thanks in advance
illhornet is offline
post #2 of 7 (permalink) Old 03-04-2007, 05:12 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 661 Post(s)
I have seen that once -- after the crankcase was grossly overfilled with oil.
GeeS is offline
post #3 of 7 (permalink) Old 03-04-2007, 05:19 PM
Date registered: Feb 2007
Vehicle: sprinter 208 cdi 2002
I've seen this before when the crank case breather got all carboned up engine couldn't breath so it spewed oil out through air filter may be worth a look a cheap place to start
Rob
rifletech is offline
post #4 of 7 (permalink) Old 03-04-2007, 06:45 PM
Date registered: Jun 2006
Vehicle: 1981 300CD, 1973 280C
Pull off the rubber breather hose at the top of the air filter. If liquid oil shoots from that I would be surprised! There should be only blow- by smoke. I also believe the crankcase breather is plugged up or restricted in some way or yes, its overfilled with oil, but you checked the level, right?
carnut1 is offline
post #5 of 7 (permalink) Old 03-04-2007, 07:04 PM Thread Starter
You're correct
I replaced the oil and, unless the dipstick is wrong, the oil level is correct. I may try lowering the oil level (a little) but the stuff coming out of the bottom of the air filter is doing that for me anyway.
Oil doesn't shoot out the top of the air filter but it does collect in the bottom.
I've pulled the oil filler cap off and there seems to be a LOT of blowby but that may be normal?
post #6 of 7 (permalink) Old 03-06-2007, 09:13 AM
KCM
Date registered: Jun 2004
Quoted: 17 Post(s)
Two things come to mind: excessive blowby and a bad diaphragm in the vacuum pump. Excessive blowby would mean the engine needs a rebuild, new rings and possibly pistons and sleeves. A bad vacuum pump diaphragm simply means a new diaphragm for the vacuum pump. You can easily check the vacuum pump by removing the line from the pump to the intake and seeing if there is oil in the line, or start the engine and see if oil spits out.
The hard starting leads me to believe you have low compression, and thus an engine rebuild is what is needed. The clearance between the piston and sleeve is only about 0.0015", so most likely there is a lot more slop than that, and it would need new pistons and sleeves too. An overhaul would likely run $1500 in parts alone, not counting labor for installing sleeves and valve work. You should also check the head and block for flatness and have them milled if necessary if you are that far.
KCM is offline
post #7 of 7 (permalink) Old 03-30-2007, 10:33 PM
ScrazySean's Avatar
Date registered: Jul 2005
Vehicle: 1981 300D
Send a message via AIM to ScrazySean
The idea is to put the oil cap back on, but dont lock it in place, if it jiggles around a little bit thats okay, but if it shoots off, that means you have bad blowby
1981 300D Anthracite Grey 358K (Daily Driver)
1981 300D Euro `Diamond Blue` paint code: '355' at least 300K (passed away)
1987 190e 2.3L Astral Silver 180K (Rear Ended)
<br>
<center>
ScrazySean is offline
    K & N air filter for 300D- a question. geekcomputing W123 E,CE,D,CD,TD,TE Class 36 03-09-2007 09:58 PM
    Air Filter 300SD 300D hyoung888888 W126 S,SE,SEC,SEL,SD,SDL Class 1 12-17-2006 07:45 PM
    FS: 3.2 V6 (etc) OEM air filter, oil filter Mann, Mahle ashman78 For Sale/Wanted/Trade/Giveaway 2 06-26-2006 07:49 AM
    300D: oil in the air filter Pol W123 E,CE,D,CD,TD,TE Class 5 06-09-2005 04:02 PM
    1982 300D oil filter cdv478 W123 E,CE,D,CD,TD,TE Class 2 05-10-2004 11:32 PM
