Starting Problem 76 280C - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 02-20-2007, 09:09 PM Thread Starter
Date registered: Feb 2007
I recently bought a 1976 280C. I don’t know the history of the car. I had to replace the carburetor with a used one and adjusted it to work good. The problem I am having is the car will start easily when it has not been driven for say 12 hours. However, if I try to start the car after it has ran for any length of time, it will not start. If I drive the car after it does start, it will die about 30 min later and, won’t start.
I have checked everything I know to do, the optical electronic ignition is working fine, I replaced the coil with a high performance coil, but still have the problem but it has spark, the fuel pressure is 3 lb. so it has fuel, I have tried different choke settings, same problem.
Does anyone have any ideas?
bobnapier is offline
post #2 of 4 (permalink) Old 02-22-2007, 04:39 AM
Date registered: Jan 2007
Quoted: 82 Post(s)
I would suspect a fuel supply or over-supply problem. Things to check:
- on a no-start, do you get a good squirt from the accelerator pump jets?
- are the idle solenoids working? With the ignition on, disconnect the wires - they should click.
- what do the plugs look like after you try to start it?
- are the secondaries sticking open?
Just to make sure you have a good supply of fuel, I recommend clean the strainer in the tank outlet, change the fuel filter, and clean the carb. Disassemble it, soak overnight in a can of carb cleaner, rinse, and blow out all passages with air. Reassemble with new top gaskets
ctaylor738 is offline
post #3 of 4 (permalink) Old 03-02-2007, 07:23 PM
vwnate1's Avatar
Date registered: Jul 2006
Vehicle: European 1974 350SLC ,'78 300CD& '80 300CD sold , '81 240D SWMBO's Car '84 300CD & Euro
Quoted: 19 Post(s)
Post Hot Hard Starting
Wierd ~
Have you yet adjusted the valves ? if they're tight as normal , they'll close up as the engine gets hot and cause hard starting from low compression .
Might also want to carry a spare new spark plug and do a hot spark test , if the spark isn't white or ble , you have a heat induced spark problem .
Let us knmow what you find .
Old German cars & motos
vintage car mechanic
vwnate1 is offline
post #4 of 4 (permalink) Old 03-03-2007, 02:20 PM
Vehicle: sprinter 208 cdi 2002
i have just checked my auto data disk fuel pressure should be 0.18-0.24bar sorry doesn't give it to me lb hope this is some help
rifletech is offline
    Problem with starting Benz-in W201 190-Class 8 04-19-2009 05:26 PM
    Starting problem Arcee43 W163 M-Class 2 01-24-2007 11:57 AM
    1994 S600 coupe "Vacuum assist pump problem and now a starting problem Bigpauly52 W140 S-Class 18 09-26-2004 12:36 AM
    Starting Problem (Back window rolls down when starting up the car) fastneutron W202 C36 AMG, C43 AMG 3 08-08-2004 10:23 AM
    Starting Problem Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 3 03-29-2001 01:05 AM
