» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > General Mercedes-Benz Forums > Vintage Mercedes-Benz
Old 02-18-2007, 09:36 AM   #1 (permalink)
Date registered: Dec 2006
Vehicle: 1976 mercedes 240d and 1967 250s
smoking problem
i am having a new problem with my 1976 240d. I changed the glowplugs, belts and fuel filter and since then it has decided to start smoking. Black smoke. Excessive black smoke. any ideas?
allgoodian is offline   Reply With Quote
Old 02-18-2007, 03:03 PM   #2 (permalink)
Djenka018's Avatar
Date registered: Jan 2005
Vehicle: '80 450SLC, RHD, Ikonengold 419, pergament 205, 82t km's
Location: Serbia, South Africa, Australia, Jamaica... actualy ROTW!
Dunno exactly, however, if bosh pump is out of timing it smokes as if it is burning wet weed inside.
Is pump timed with belt you changed or have you removed the belt?
Djenka018 is offline   Reply With Quote
Old 02-18-2007, 06:28 PM   #3 (permalink)
diametricalbenz's Avatar
Date registered: Oct 2005
Vehicle: 77' 6.9, 74 240D, 76 300D, 1996 Ram 5.9L Cummins
None of those things would affect the engine in making black smoke. Either the pump is not adjusted properly or timed incorrectly. The belts just turn the accessories.
1977 - W116 - 6.9
1976 - W115 - 300D - Disassembled
1974 - W115 - 240D 4 SP Manual - Almost under Turbo OM617 Power!
diametricalbenz is offline   Reply With Quote
Old 02-18-2007, 07:30 PM   #4 (permalink)
how do you set the timing on the pump?
Old 02-18-2007, 11:20 PM   #5 (permalink)
0tto's Avatar
Date registered: Feb 2007
obviously there not proper balance fuel/air mixture.
system deliver too much fuel or there is not enough air.
1. check injectors (every 120 000 it should be cleaned)
2. dirty air filter
3. faulty injectors pump
4. problem with valves. can be clogged due to faulty EGR unit
0tto is offline   Reply With Quote
Still Smoking... Gregs300CD W123 E,CE,D,CD,TD,TE Class 8 09-23-2006 03:33 PM
300D Turbo smoking problem shox75 W124 E,CE,D,TD Class 4 07-14-2006 06:08 PM
Smoking Nehdad R129 SL Class 3 08-03-2003 06:37 AM
Smoking Big D W126 S,SE,SEC,SEL,SD,SDL Class 3 07-24-2003 08:54 PM
brakes smoking j R170 SLK Class 8 06-05-2001 04:30 AM
