Engine Swap W108 280S to 300D Diesel - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 02-16-2007, 10:21 PM Thread Starter
Date registered: Feb 2007
Hi All,
I was hoping someone might be able to assist. My old 280S engine is pretty tired and ready for a re-build. I have been entertaining the idea of trying to fit a 300D engine & auto. I was wanting to get into the bio fuel thing with some friends who are already running their cars on it.
Has anyone done this conversion? If so, could they tell me the following. Does the 300D engine bolt up to the same engine mounts and auto mount locations in the 280S? Are the exhaust manifolds on the same side? Are their any other major issues involved in the swap?
Any assistance would be much appretiated.
Peter.
pookybbb is offline
post #2 of 4 (permalink) Old 09-20-2009, 04:41 AM
Date registered: Dec 2007
Hi,
I did the OM617 (N/A) into 280S about a year ago. (When I say "I", I mean my $100-an-hour mechanic.)
I love the 108 shape and the 300D engine has a very big reputation for longevity and yes, I was going to run it on biodiesel, so I put my money where my mouth was.
My floorshift 1970 would allow an easy match-up of the transmission, but the engine new arms were fabricated from thick steel, and the engine mounts had to be slightly adapted to fit.
The rest of the 60 hours of work was down to the multitude of changes required to lengthen certain hoses and leads, and shorten others, hook-up the ignition to the glow plugs and a bunch of other stuff.
Assuming you've got the money or the know-how to do the job yourself, the biggest thing to look out for is the vibration that can come into the cabin and through the steering wheel. Make sure you've got plenty of insulation under the hood and see if you can get some engine shock absorber mounts made up.
One final word of warning; make sure you do a compression test of the 300D motor before purchase and installation. The one I had put in worked perfectly on the way home from the mechanic and suffered a radical loss of compression within a week! I have since sourced another engine that's had a top-end rebuild and will hopefully be installing it this week.
Once everything is done, I will hopefully have a beautiful car that will still be running when pump petrol is too expensive for the average motorist.
Good luck.
Dweezil
Dweezil is offline
post #3 of 4 (permalink) Old 09-20-2009, 07:14 AM
Ed Mclass's Avatar
Vehicle: 90 300 SE ,85 300 GD
You can certainly buy a 300D cheap right now and save your 280 as is for the weekend!
Ed Mclass is offline
post #4 of 4 (permalink) Old 09-20-2009, 09:59 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 99 Post(s)
You know, most countries consider it a capital crime to swap ANY kind of diesel into a 108 ... Better be careful or you might be caned or something.
Grubeguy is offline
    '76 W123 300D swap out for later Diesel ? MarkAC Vintage Mercedes-Benz 1 12-22-2005 04:34 AM
    1969 280S engine swap magnusdog Vintage Mercedes-Benz 3 11-25-2005 09:13 PM
    W108 engine swap? Danborn Vintage Mercedes-Benz 1 07-07-2005 07:15 AM
    Engine Swap diesel coachgeo Unimog 14 03-21-2005 10:49 AM
    Diesel Engine Swap - 300E mafia_190D W124 E,CE,D,TD Class 2 08-14-2004 03:29 PM
