Go Back   Benzworld.org - Mercedes Benz Discussion Forum > General Mercedes-Benz Forums > Vintage Mercedes-Benz
Old 02-16-2007, 09:48 AM   #1 (permalink)
baker462's Avatar
Date registered: Jan 2007
Vehicle: 1973 280C
Clean Connections
I am going to repleace all the fuses in my 1973 280c as they all look VERY old and brittle.
I have been told to make sure I disconnect the battery and clean all the connections on the fuse pannel.
What do you guys recomend to use to clean the posts?
(so far I have heard use scotch brite, I am assuming they ment scouring pads)
Thanks
baker462 is offline   Reply With Quote
Old 02-20-2007, 09:20 AM   #2 (permalink)
Date registered: Nov 2006
Vehicle: 1976 300d @460k
I used some fine steel wool and a little bit of electrical contact cleaner to soften every thing up. replacing that last fuse is always hard for me with out small pliers as there is no space for your fingers on either side
otm646 is offline   Reply With Quote
OT: GPS Connections Braingears G-Class 3 11-17-2005 05:33 AM
Command 2.0 connections woz W163 M-Class 1 04-03-2004 03:33 PM
Clean "Fuel Pump bayonet connections" Chupper W124 E,CE,D,TD Class 1 12-03-2002 06:46 AM
Connections for the NAV Stewart W163 M-Class 4 04-11-2002 03:47 AM
how do you people clean your rims. my r perpetually dirty and its a pain to clean.NE1 use spray Mind-X R170 SLK Class 11 02-26-2001 06:50 AM
